rear diff/t-case??? LEAK
Old May 27, 2017 | 11:43 AM
Cowen88's Avatar
Tight as I can get it with a 1/2 breaker bar.
Old May 27, 2017 | 02:35 PM
millball's Avatar
How does it feel when you rotate it?? Smooth/? play gone??
Old May 27, 2017 | 02:44 PM
millball's Avatar
Originally Posted by Cowen88
Dropped the driveshaft and the pinion but was really loose. Tightened it up but can't get it to where it was previously staked. And advice? Impact? Or just tighten with a torque wrench?
If the flange was loose before, and now its tight you've likely tightened it past the original stake. This is OK. Tighten to about 130 fp if you can and restake the nut wherever it is.
You did pull the flange and replace the seal dincha??
Old May 27, 2017 | 02:46 PM
Cowen88's Avatar
Play is gone. Drove it around the block and it felt good. No noise. Deflector in still lose though. Leak is also gone.
Old May 27, 2017 | 02:48 PM
  #25
Cowen88's Avatar
Didn't replace seal or deflector.
Old May 27, 2017 | 02:53 PM
  #26
millball's Avatar
Deflector mght simply press back on. Never would have been a better time to replace the seal, but if it doesn't leak, you are golden.
Might last long time,, Good luck.
Old May 27, 2017 | 04:33 PM
  #27
Cowen88's Avatar
It way to big. Warped under stress probably. Should have taken the flange out but wasn't sure if I'd get it back together and working properly if I did. I have no FTV/ FIPG at the moment so I'm just waiting till after the weekend to order more part and supplies. Maybe some tools also. And recommendations would be helpful. I'll keep the thread updated and let everyone know how long my rear diff holds up
