Rear brakes locking
Old Mar 29, 2016 | 04:57 AM
mrroach2839's Avatar
Rear brakes locking
I have a 87 Pickup, 2.4 2BRL. The rear brakes will lock up in the first 10-15 minutes of driving, and will eventually release and drive fine for a bit before locking again. It varies from a small hang to completely locking up. The cooler the temperature the more apt it is to happen. I've replaced shoes and wheel cylinders on both side, adjusted both sides, and bled the system. Problem is still there. Anyone else had this issue, it's new to me? Thanks for the advice.
Old Apr 4, 2016 | 11:13 AM
SilentBounty's Avatar
I had this same problem. I did the whole shebang. Wheel cylinders, shoes, springs, adjusters, drums, parking brake cables. It solved my issue. Maybe your drums are warped and still grabbing the shoes?
Also, did you bleed the LSPV on the frame above?
Old Apr 5, 2016 | 11:09 AM
I haven't replaced the springs or drums. I lubricated the cables, originally thinking the problem was being caused by the park brake. I recently bled and adjusted the LSPV, and within 10 minutes of running approximately 45 mph, the rear brakes locked worse than ever.
Andy A
Jun 21, 2016 05:40 PM
user 82300
Jan 26, 2016 01:29 AM
farmershooter
Jan 16, 2016 11:09 PM
Deerail
Jan 11, 2016 06:27 AM
mapemberton12
Jan 10, 2016 02:01 PM
