Radiator and exhaust???s
Old Jun 29, 2019 | 09:53 AM
Spread5150's Avatar
5 Year Member
My 94 standard 4x4 3.0 standard is coming along. I have sunk a bunch of money into her and right now it’s running great. On to the exhaust.
I am am interested in the LC Engineering turbo style exhaust and cat. The ones I have now are rusted through, look like poo and need to go. Anyone running these and have any tips on what needs to be replaced along with it. I was thinking this is the time for a new o2 sensor since I have no idea how old the one in there is. I have a new functioning EGR (should have deleted it when instead of replacing ) and one (I believe upstream in front of the cat ) o2 sensor. Since I have the EGR is this a California emissions ? Not sure. I currently have no codes.
The radiator is also pretty tired. I am thinking aluminum 3 row (eBay) But don’t know which one. There is a bunch of them offered. The reviews on this one say the transmission cooling lines don’t fit this and that. Does a standard have these lines ? I only see in and out on my current setup. I will replace these hoses at this time also. I suppose a new thermostat would be a good idea at this time. I see the 180 and 190 options. Any input ?
https://www.ebay.com/itm/Aluminum-Ra...kAAOSwTM5Y32w-
Old Jul 1, 2019 | 12:00 PM
Woodmac64's Avatar
Hey Spread5150,
I bought CSF's 3 row radiator from PartsContainer on Ebay for my 1991 3.0 DLX 5 speed and have been completely happy with it. A bit more expensive than the aluminum one you're considering. The manual transmission does not have the cooling lines. I just capped the tranny cooler hookups on the radiator I bought.
Old Jul 1, 2019 | 01:03 PM
Spread5150's Avatar
5 Year Member
I looked at that one as well. People seemed to not like the plastic drain plugs on that model as they leaked ??? What did you block the cooler lines with ? Knowing i need not worry about the cooler lines is a big help.
Old Jul 2, 2019 | 12:02 AM
Woodmac64's Avatar
I forget the size(1/4 or 5/16), but it was just a couple of rubber vacuum line caps I had on hand to cap the lines. I haven’t had any issues with the plastic drain plug, and I’ve put easily 25k miles on the radiator. I also used a Stant 180 degree thermostat over the winter and had good performance from it, too. Like you though, I’m looking to invest in the LCE exhaust and catalytic converter.
Ben Fulcher
Feb 3, 2017 04:01 AM
jstluise
Jul 30, 2013 11:49 AM
twowheelwarehouse
3.4 Swaps
Jul 11, 2013 09:26 AM
Blacksmith04
Apr 13, 2008 02:24 AM
ncpaladin
Oct 26, 2007 02:07 PM
