R-134a Conversion - How did it work out?
Old Oct 28, 2020 | 06:04 AM
dbittle's Avatar
Originally Posted by itscrazytom
That’s quite a big difference between your research and the FSM (7oz vs 4.1oz). I would follow the directions from the “instructions” pamphlet you get with the new compressor.
It is worth buying AC dye to add into your mineral oil. My first shot at refilling, I had a hole in the low pressure line, I was quick to notice due to the dye oozing out. Vacuum was good until I pressurized the system.
I will definitely add the dye. I just drained the old compressor. It had no oil left in it at all. I will admit that was a bit of a surprise. Next step will be to see how much is in the new compressor.
Old Oct 29, 2020 | 10:53 AM
dbittle's Avatar
Little bit of an update on the AC project. I was able to verify that the total system oil charge is 7 ounces. I was able to drain 2 ounces out of my Denso compressor, so added back an ounce to bring it up to 3 (or 3.5 figuring that there was more in it than I was able to drain out by turning it upside down over a measuring cup). I will split 3.5 ounces between the other system components and call it good!
Old Oct 29, 2020 | 01:51 PM
itscrazytom's Avatar
This is based on my one experience, I’m not an AC mechanic by any means but when I first charged my Denso Reman compressor with R134, the clutch would not engage. Had the truck at 1500 RPM, AC switch on, fan blowing HI. I read somewhere that new compressors will not engage without the proper PSI and the can did not provide enough pressure. So I manually engaged my clutch by wiring directly to the battery. Once the system took in one can, I plugged the compressor back to where it should, and everything else is history.
faber
Nov 24, 2019 02:13 PM
Bigmat
Jul 14, 2017 08:30 AM
Discombobulated
May 13, 2012 05:29 PM
XtraSlow_XtraCab
Aug 13, 2007 06:22 PM
FireMan
Mar 31, 2004 11:15 PM
