Question about replacing Air Control Valve pickup 3VZE 91 4x4
Old Jul 11, 2016 | 07:44 AM
quevedofredy's Avatar
Hi, I have a toyota truck 1991 v6, MT, and I need to replace the Air Control Valve that is located at the bottom of the PS pump because it is broken. I was wondering if it is an easy job as to swap the old valve with the new one? Is there anything else inside the valve that I should care when taking off (I was reading that there is a union seat there)? Do the vacuum hoses that go from the valve to the plenum need to be located in some order or It will work if I just plug them in?
Thanks for your advice
Old Jul 11, 2016 | 08:26 AM
scope103's Avatar
There is no order to the vacuum lines; the valve just connects the two together when the PS pump is "working hard."
I've never replaced the valve by itself; I just sprung for a rebuilt pump that had a new valve already.
Old Jul 11, 2016 | 11:39 AM
I just replace it, when I took off the old valve a lot of steering fluid came out , so I place the new one and put some fluid back to the reservoir to adjust it. I noticed now that when I put at full lock the wheels either right or left the rpms go from 900 to 800 aprox. is that a normal behavior?
Barnes 4wd
Vendor Advertising
16
Nov 17, 2016 10:22 AM
Maple
Jun 28, 2016 07:31 PM
quevedofredy
Jun 25, 2016 03:31 PM
Murfy101
Apr 18, 2016 07:55 AM
Simian
Apr 16, 2016 08:50 AM
