question about 86 22rt
Old May 1, 2010 | 01:01 PM
86bedlesstoy's Avatar
So the turbo was taken off the truck?
Old May 1, 2010 | 01:03 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
yes, that Turbo is GONE! It took the 1st thing smoking!
It just flew into Albuquerque, and boy are it's arms tired!
Old May 1, 2010 | 02:43 PM
dburke0430's Avatar
i think this is the circle you were talking about. its not drilled or tapped so would you assume that its just the 22re block?
Old May 1, 2010 | 03:28 PM
toyota4x4907's Avatar
Yes there is a difference between '86 and '89 exhaust manifolds. '86 usually had the O2 sensor in the exhaust manifold, like as pictured, '89's were just before the catalytic converter further down the pipe.
Old May 1, 2010 | 07:44 PM
  #25
PismoJoe's Avatar
I think that the "oil cooler" under the oil filter is actually an oil pressure sender unit for your gauge cluster. Those are found in the same location on 22RE's
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
