PS fluid put in my PS Pump instead of ATF!
Old Jun 19, 2008 | 10:51 AM
86tuning's Avatar
Originally Posted by shansethp
okay then what are they talking about by putting in ATF in place of the PS fluid??
It's not 'in place of' p/s fluid.
Dexron type ATF is what Toyota recommends for the p/s system. Using p/s fluid is NOT recommended by the Toyota factory. End of story.
Old Jun 19, 2008 | 02:45 PM
dafried's Avatar
Wow - thanks for getting on this. It sounds like I am not in an immediate crisis, but I need to bleed/purge/flush the PS stuff through. A little will probably not do me any harm.
I know this is extreme, but my time may be worth more than my money at the moment. I can buy a new PS pump (minus the reservoir) cheap. Should I simply replace the pump and fill? Is that faster, or is the bleed procedure the same.
Thanks
Dafried
Old Jun 19, 2008 | 05:43 PM
tc's Avatar
tc
Most of the fluid is in the lines and the steering box - you need to flush it.
Old Jun 19, 2008 | 05:47 PM
dafried's Avatar
Fair enuf - thanks everybody!
bigjstang
Jun 2, 2025 03:56 PM
smthwsn357
May 1, 2024 07:28 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
