ProComp Bracket Lift
Old Jan 8, 2009 | 09:11 PM
BigBluePile's Avatar
Originally Posted by abecedarian
@BigBluePile-
even though this was a 'used' kit I purchased, it bolted up straight through to the frame without any issues at all..... Can't say the stock/ OEM 'kit' wouldn't have issues though since what I bought came with Rancho shocks instead of the ProComp shocks... however, I can't see the ProComp shocks being THAT much larger in diameter than the Rancho's to require clearancing the frame... particularly when the front shocks mount outboard of the frame at the bottom and are still outboard from the frame at the top.
Well, I thought it was silly too. I'm willing to bet the procomp shocks are the same size as the ranchos and I couldn't believe it either but the scrape marks and subsequent dents from that corner of the bracketry made me a believer. Maybe, I shouldn't say "frame" per say, but where the new drop bracket mounts to where the bumpstop use to go(the little white arrow). Plus, my instructions say to do it. Which is what REALLY chapped my arse about the whole deal having a "shop" do it.
Old Jan 8, 2009 | 09:17 PM
abecedarian's Avatar
You've got a little bit of cranked-in-t'bar- lift there.... Makes a little more sense now.
The LCA's should be nearly horizontal for stock + the 4" lift from the kit.
Old Jan 8, 2009 | 11:30 PM
drew303's Avatar
now i know why my lower front crossmember was chopped on the pass side when i bought my truck (no lift) ... you have to cut the inner tab off to fit the dif
see learn something new everday... and re-realize bracket lifts suck
Old Jan 8, 2009 | 11:46 PM
guess I'm gonna have to go out in the morning and take photos of my procomp II lift showing the shocks DON'T hit the lift brackets.
you could look at this photo (note no scratches in the paint on the shock after a year of use):
and see it... but I'll get photos when the light is better.
Old Jan 9, 2009 | 01:54 PM
  #25
It is possible that my lift bracket may vary from yours. The shocks only hit at full extension. Like I said, after the main alignment to true the suspension up after the lift there was a HUGE gap between the shock and the brace. Also, I've relaxed my torsion bars to where they're suppose to be. It is wierd that yours didn't have that INITIAL problem.
Now if I could only decide on a winch bumper...where's ScottyC at...!
Old Jan 9, 2009 | 05:32 PM
  #26
I doubt your lift kit varies much from mine, but looking at the pics, your shocks may be a larger diameter body than mine.
Old Jan 9, 2009 | 08:48 PM
  #27
It doesn't matter, I looked over the drop bracket again and mine does look different. Bottom line, the kit is very solid and holds up to plenty of abuse!!
Old Jan 9, 2009 | 09:21 PM
  #28
Shh... don't tell anyone there is an IFS lift kit that actually works.
Some people make lots of money due to weak IFS kits.
Old Jan 9, 2009 | 09:52 PM
  #29
Tofer's Avatar
Sponsor
i want to know how Pro Comp Lift Kit for 79-85 Toyota Pickup/4Runner 4x4
Stage 1 achieves a lift of 4" while maintaining stock ride and wheel travel along with factory steering geometry and CV axle angle.
Comes with ES Series Shocks
Old Jan 9, 2009 | 10:37 PM
  #30
/me pokes Tofer in the "pay attention" spot.
Old Jan 9, 2009 | 10:48 PM
  #31
Tofer's Avatar
Sponsor
i was born with out one of those....
Old Jan 10, 2009 | 08:26 AM
  #32
iamsuperbleeder's Avatar
all I see is a little white box with a red "X" in it
Old Sep 5, 2012 | 12:54 PM
  #33
MT YOTA's Avatar
Old thread but I could use some advise. I am in the middle of installing the stage 2 kit on my 91 SR5 x-cab. I have the front completely on except for the strut bars. The holes in the bracket that mount to the frame dont line up. Well one of the two holes does on the drivers side. I cant get either bolt in on the passenger side. Its as if the bar is too long. I think I will have to modify the bar. I was curious if anyone else has experienced this before...
Luvmeye22re
Aug 4, 2015 03:53 PM
coffey50
Jul 28, 2015 10:55 AM
kirkrunner
Jul 27, 2015 07:59 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
