Preparing for mud racing... Suggestions?
Old 01-20-2008, 05:31 PM
iamspt's Avatar
Cool Preparing for mud racing... Suggestions?
Have a 88 toyota PU, 4 cycl with a 4 inch suspension lift and 33 inch tires. I am going to hang with the boys this year at the mud races. What mods / equipment will best prepare me anf my truck to be competitive? Currenty have swamper radials all the way around.
Is there a better tire to use in mud only? Boggers? Can the engine handle that roating weight under load?
Should I do lockers? Front, rear or both?
What else can you think of?
Old 01-20-2008, 05:36 PM
bballchrism's Avatar
i would try to put a snorkel on or put the air filter in the cab and lockers would help a lot and some paddle tire on the back would be sweet
Old 01-20-2008, 05:38 PM
Sponsor
Tofer's Avatar
Small Block, 38" boggers, lockers front / rear, relocated radiator to the bed, confederate flag, and a GIT-R-DUN sticker in the rear window.
Old 01-20-2008, 05:41 PM
Doomist's Avatar
Soooo Kinda something along the lines of these....
Old 01-20-2008, 05:58 PM
standardbyker88's Avatar
wow. almost didnt recognize that as a fullsize 70s dodge. i dont get why he cut the fenders so far. its never going to rub. even stock. hmm. k.
Old 01-20-2008, 06:03 PM
EWAYota's Avatar
If your planning on hanging with them, a 22r ain't going to cut it.
Depending on the lift, remove the lift block in the rear and go all leaf springs.
Old 01-20-2008, 06:07 PM
CJM
CJM's Avatar
You aint gonna be able to hang without a v8 and at least 35's and a big ol lift.
Old 01-20-2008, 10:10 PM
just a 22re's Avatar
wow run stock and when you get stuck just say hey its all stock boo whoo lol but thats just me and if you do get all the way through say ha ha my yota is stock and you got $$$$$$$$ into yours so ha
Old 01-20-2008, 10:19 PM
Trustyrusty's Avatar
Dunno, I got like 5th place at the mud runs in town (out of like 30 people)... And thats when I was rockin bald firestones, stock rims, rotted out exhaust, and just learning stick... Then all the rednecks gave me the bird...
Old 01-21-2008, 01:03 AM
ovrrdrive's Avatar
These trucks all had the stock 22r or RE in them and did really well...
Of course, then there was this guy. He had a V8, Rockwells, and probably 44" boggers...
Of all the trucks there, these seemed to perform the best:
Notice anything in common about them?
Old 01-21-2008, 07:33 AM
Tacoclimber's Avatar
They're ugly as all get out?
Old 01-21-2008, 07:47 AM
ovrrdrive's Avatar
You know what they say, beauty really is in the eye of the beholder...
I was thinking big lifts, big tires, and (can't tell from the pics but) big horsepower...
Old 01-21-2008, 08:13 AM
Belize Off Road Team's Avatar
there is one guy who has a 3rd gen pick-up with the 3.0 and calls his truck ColdFire up in Central British Columbia. and he beats most people up there who have big ford engines. and he has about 4" lift and 35" Super swampers.
Old 01-21-2008, 10:07 AM
I was being facetious...
Old 01-21-2008, 10:18 AM
98sr5tacoma's Avatar
Old 01-21-2008, 10:29 AM
Toyvana's Avatar
I think with proper gearing, a good size lift and lockers your 22re Toyota will do fine.
Old 01-21-2008, 05:02 PM
mr toytech's Avatar
and the right tires!!!
Old 01-21-2008, 07:43 PM
MrArmyAnt's Avatar
The one advantage you have over full size is weight, and I would take full advantage of that, make everything fiberglass. I have a 77k5 with a built v8. Thing would run thru hell if I told it to but slow down at all and it sank like a brick (I think with 3/4 tons I was nearing 6000 pounds) weight decrease increase power to weight ratio, lowers PSI on the ground, and improves handling and breaking.
Oh an 33's wont cut it. I say do at LEAST 35" ground hawgs (i used to have tsls, and if you are stuck going forwards your probably stuck going back, might as well have it all one way.)
Old 01-22-2008, 12:38 AM
ovrrdrive's Avatar
For serious mudding a set of cut boggers is the only way to go if you need it to still be DOT legal. If the street isn't an issue tractor tires.
Old 01-22-2008, 05:08 AM
Yodaforce's Avatar
Strip the whole truck down to bare neccesities. Lighten your weight, lock ATLEAST the rear, have good tread that bites, tight suspension, waterproof everything electrical, run an electric fan with a master switch inside (turn it off when you hit the mud), protect the radiator from the thick mud, and have a strap allready tied on the front or rear so when you don't make it, it will take less time to get you out of the way and less time for the crowd to laugh or poke fun at you. Good luck.
Quick Reply: Preparing for mud racing... Suggestions?
