They do bolt right into the doors, just in a different location, lower, and using a different set of holes. I needed to adjust the position of the arm so I used a small battery I had laying around. Had the new regulators installed in 10 mins, super easy. Getting the wires thru the door jambuh took a bit of time. Door panels cut easy w a drywall knife, used a cutting wheel for the switch holes. The drivers switch I put too close to the door handle and the regulator hits it if I go all the way down. Going to make a spacer from pine. Nailed it on the passenger side, done in 20 mins. Friggin love it, they are fast and quiet! Got some power locks coming soon and wanna have those wired to a noisemaker car alarm for the keyless entry.
Shem Make sure to zip tie the wire at the top right of the doot to keep it away from the regulator arm moving arrows show bolt locations the wiring kit cutting the panel, go further! ps finished Gotta fill those holes
