power steering swap
Old Feb 18, 2013 | 03:25 PM
Ballen's Avatar
power steering swap
90 4 runner 6 cycl.
replaceing my pump with a good used one anything I should know .never done one ,does it need to be blead to get air out if so how do you do you do it?
Thanks
Brian
Old Feb 18, 2013 | 05:45 PM
brianh699's Avatar
Yes it will need to be bled. After you replace the pump jack front end up fill reservoir with fluid, turn wheels in both directions 2 or 3 times recheck fluid. Start the engine and turn wheels both directions 2 or 3 times. Lower the vehicle with engine still running turn wheels both directions 2 or 3 times. Check that fluid is not foamy or cloudy and doesn't rise over maximum when engine is stopped. Maximum fluid rise is 5mm.
Old Feb 18, 2013 | 05:49 PM
brianh699's Avatar
If your swapping pulleys remove the pulley bolt before you take the belt off.
Flying91
45
Apr 11, 2024 04:39 PM
mlavery85
Jul 12, 2015 10:33 AM
cars-guy
Jul 11, 2015 07:51 PM
jon.r
Jul 11, 2015 03:34 PM
