power steering leak (repair-replace)
Old May 21, 2008 | 05:56 PM
HAVOC's Avatar
Question power steering leak (repair-replace)
So, I'm almost to the point of pulling my engine out to rebuild it. As I was taking stuff apart under the hood I made notes on what will need to be replaced (radiator, hoses, belts). The right side of the engine (3.0L) was especially dirty from the P/S pump leaking.
Should I buy a seal kit, a new/rebuilt pump from the dealer or a rebuilt pump from NAPA?
Thanks.
Old May 22, 2008 | 05:13 AM
dirtoyboy's Avatar
I would just buy a used, dry pump and slap it in.
Old May 22, 2008 | 05:48 AM
anotherjeff's Avatar
Rebuilding your old pump is going to be the cheapest fix. Helps to have an FSM.
Old May 22, 2008 | 10:16 AM
Jay351's Avatar
I was going to rebuild mine, but I found a used one with no leaks for 40 bucks. I would try and find a used one.
Old May 23, 2008 | 08:20 AM
InternetRoadkill's Avatar
Rebuild is easy. Use the OEM kit from the dealer (about $40).
Old May 23, 2008 | 01:36 PM
supercub's Avatar
Replaced mine w/ a reman'd unit from Autozone. "New" one started leaking at the double copper gasket fitting within a few months. I'm not sure if its a faulty part or intaller error. I think w/ the core exhanged it was about 50 bucks.
Old May 23, 2008 | 02:50 PM
HAVOC's Avatar
When I get the bearings/gasket set I'll get a price on the P/S seal kit.
Sleaker
Aug 26, 2020 06:03 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
cars-guy
Jul 11, 2015 07:51 PM
jon.r
Jul 11, 2015 03:34 PM
nick b
Jul 11, 2015 04:38 AM
