Power Antenna Dead
Old Feb 17, 2013 | 05:33 PM
ksti's Avatar
Power Antenna Dead
My power antenna finally bit it.
I don't want to put another power antenna in.
So I wondering if I cant bolt up a standard antenna (no power)
without having to modify it?.
Can't find any threads directly related.
Any help is always appreciated.
Old Feb 17, 2013 | 06:09 PM
Co_94_PU's Avatar
If i'm remebering right it's the same mounts. or one of the power mounting holes. Should have been a recent post on this. Try "rubber duck" in a search.
Old Feb 18, 2013 | 09:49 AM
ksti's Avatar
Couldn't find anything under"rubber duck".
Thanks for the response.
Just did a little more researching and measuring and
ordered what I needed.
I can re-work mounting tab myself if needed.
I'm good to go.
Old Feb 18, 2013 | 11:16 AM
Webbuff's Avatar
I used the one here which was in a reply to a thread I posted a bit ago
http://www.crutchfield.com/p_12044TY...u-Antenna.html
Post in question:
https://www.yotatech.com/forums/f116...cement-257618/
The antenna fit fine, but turns out my radio is crap so need to replace it hehe.
Old Feb 19, 2013 | 07:23 AM
ksti's Avatar
Post in question:
Yea, I saw that one, but just opted for an exact fit.
I'm pretty sure it will work.
Thanks for the links.
Old Feb 20, 2013 | 10:43 AM
monyman's Avatar
My automatic extending/collapsing antenna broke off so I got another one. Broke it off, too, and was upset at myself for not being more careful. I replaced that one with a marine antenna wire that I laid under my dash. It works good. My local stereo shop did it while I waited. It looks clean with no antenna sticking up.
Old Feb 20, 2013 | 11:05 AM
Webbuff's Avatar
What did you fill the hole in the fender with, out of curiosity?
Old Feb 20, 2013 | 02:24 PM
ksti's Avatar
^ X2 and if so do you have a pic?
Old Feb 20, 2013 | 04:09 PM
monyman's Avatar
My post broke right at the fender plug so I just left it. Kinda cheesy, but you can't really tell at 10' or more.
Old Feb 20, 2013 | 04:32 PM
StewsRunner's Avatar
This is what 92 Toy suggested to me. . I however was dumb and decided to do a Tacoma Whip antenna. . .
Old Feb 20, 2013 | 04:43 PM
banditbuggy145's Avatar
Yes it will fit with no mods because i did the same to mine. I didn't bother sealing the hole,but unless your planning on driving in rivers, you should be fine. You could probably seal it with some kind of silicone.
Old Feb 20, 2013 | 07:46 PM
ksti's Avatar
I'm supposed to receive the antenna on Friday and will post some pic's of the exchange this weekend.
Maybe a mini write up.
Possibly it will help someone else.
Old Feb 23, 2013 | 03:10 PM
ksti's Avatar
Replaced antenna from power to standard.
Pretty straight forward and easy to do.
Removed 5 bolts from splash guard starting from the bottom and just slide it out of way.
remove antenna assembly mounting bolt.
Install replacement antenna to mounting plate it comes with mounting clip bracket. (bottom of pic)
Run antenna plug through original pilot hole and plug in to stereo unit.
It was a little difficult to plug in to unit as I only removed glove box assembly.
I didn't want to to disassemble the whole lower dash area.
Very cramped area, after a lot of yelling and dislocating body parts I was able to plug it in
Hopefully this can help someone if needed.
The finished product---vv--- great reception again.
Old Feb 23, 2013 | 07:26 PM
Co_94_PU's Avatar
I have my stock/toyota no stereo fender plug still, uh somewhere I dunno where I put that now that I thought of it.
Anyway.. You can fill the old hole with one of those if you can find the part number. OR get creative with some epoxy.
Material:
1 can, bottle or pen of touchup paint.
1 nozzle of epoxy
2 pieces 3-4" long & full width AL foil, folded over 1-2" wide
1 roll of duct tape.
1 roll of masking tape.
1-2 pieces of sand paper
Undo the inner fender as above.
Using masking tape mark off an area 1/2-1/4 inch outside the edge of the hole, you want two layers of tape here to protect the paint from the next step.
Sand down to metal around the hole inside the area you masked off.
Apply two(or more) layers more of masking tape all around the masked area, this forms a rim for the epoxy to lap onto the outside of the fender.
Place 1pc foil on the inside covering the hole. Tape this in place with the duct tape making sure you have all the edges covered.
Attach the second piece of foil to the outside by taping it vertically and only at the bottom, eg a flap attached at the bottom.
Mix and apply epoxy to the face of the hole allowing it to flow onto the inner foil and inside the hole, it should form a bit of an overlap on the inside and outside "H" shaped to hold it in place.
"Paint" some more epoxy onto the outside, and fold the outer foil upwards as you go. The outter foil will help it stay in place on the fender and keep it from running. Tape the edges of the foil so it doesn't leak while curing.
After the epoxy cures to it's gel stage, this is aproximately the "pot life", you can peel the outer foil off and all but the last layer of masking tape. It's ok to skip this step.
Once fully cured, peel off any masking tape and break off any epoxy ontop of the tape.
Reapply a single layer of masking tape, 2-3(or more!) inchs all the way around your new epoxy.
Carefully sand down the epoxy and feather the edges down to the tape level.
VERY carefully sand down the edge of the epoxy to the paint level. using high grit (200+)
Apply a shot of primer, wait. Apply you color matched paint, wait. Apply a shot of clear coat if you want, wait. Gently sand out any paint runs or blemishs with high grit.
Celebrate!
yeah I know no one asked, well they kind of did You can also use a body putty but you'd want to seal the inside of that and it's prone to shrinkage.
Old Feb 28, 2013 | 09:58 AM
Outsane's Avatar
what was wrong with your old antenna?
I have been wondering if there is a place to buy just the metal sheathes...
Old Feb 28, 2013 | 11:18 AM
ksti's Avatar
Material:
1 nozzle of epoxy
Celebrate!
What's all this about?
All I did was replace a simple antenna.
Old Feb 28, 2013 | 11:39 AM
Co_94_PU's Avatar
Somebody asked how to fill the hole You could of course use a bondo w/ fiberglass and follow the directions on the can, a regular filler will shrink and fall out.
Old Feb 28, 2013 | 01:59 PM
ksti's Avatar
Are you asking me?, if so, the motor was jammed up with broken plastic cable pieces inside.
Not a fan of power antenna's anyway.
Forgive me, but what are the metal sheathes you referring to.
Do you possibly have a pic of them?
Old Feb 28, 2013 | 02:24 PM
Outsane's Avatar
the actual antenna part..
can I have your old power antenna to fix mine?
Old Feb 28, 2013 | 04:02 PM
ksti's Avatar
Are you looking for the antenna mast or the the whole assembly?
I just hope I didn't throw the mast away.
I will check when I get home, about 7:30pm.
