Post Your Pics!!!
Old Jul 12, 2009 | 09:25 PM
  #1461
kinzer's Avatar
here's my recent pics... freshly sas's as of today! recent rock sliders, fender flares, blacked out grill, and reverse light bar. next is tires gears lockers and a buddys dual case setup
Old Jul 12, 2009 | 09:46 PM
  #1462
Tubbyfatty's Avatar
That is awesome~!!!!
Old Jul 12, 2009 | 09:48 PM
  #1463
Blue Bowtie's Avatar
^^ Looks really good man.
Old Jul 13, 2009 | 08:17 AM
  #1464
T4L's Avatar
T4L
Originally Posted by Tubbyfatty
Yea and you have kids right?
Yeah....they rely on those running boards. If/when I can afford some sliders....the steps will come off for sure. Until then, they will protect that area from rock chips, mud, and other (everyday) driving hazards
Old Jul 13, 2009 | 10:15 AM
  #1465
tesh's Avatar
Originally Posted by mattaway
that's an epic picture man, i like it!
Thanks for the comments guys!
Here's more pics of her first <and last > wheeling trip so far - got some clutch trouble and won't know for sure if it's a master cyl. or full out clutch till later this week i guess...pm me if you think you know this topic...
on to the pics!
Old Jul 14, 2009 | 02:52 PM
  #1466
cblackard's Avatar
My Truck
Just a couple of my 91 SR5 X-tra Cab. SAS and 4.3 Vortec conversions.
Old Jul 14, 2009 | 03:39 PM
  #1467
Toreador's Avatar
how's the 4.3 run?
Old Jul 15, 2009 | 09:08 AM
  #1468
cblackard's Avatar
Originally Posted by Toreador
how's the 4.3 run?
The engine run GREAT, but I am having fuel delivery issues to the engine using the electric fuel pump. I am quite sure its a vapor lock issue because the problem only occurs if the truck is sitting idle (you can see the bowl is dry through the site glass of the carb). The fuel line runs a little closer to the exhaust than what I would like, and the pump is up under the hood. I plan to relocate the pump back at the tank and re-route the lines away from the exhaust. This should solve the issue.
I have lots of power with the 5.29:1 gears (runs high RPMs though) and 42" swampers. I am thinking about reducing the gears to 4.88:1 to see how much is lost in 5th gear torque.
Just to help along those that want to make this switch, please do not get rid of your Toyota CPU....Although I think I can get all of the gauges to work with Toyota sending units and tapping into the wire harness, I think the speedo is not working due to the CPU missing. Tach, temp, oil pressure and fuel all seem to work ok. I have aftermarket gauges connected right now to get a feel for the trucks operating parameters, but I think I can reconnect the factory gauges since I now have a good idea how they match up to the aftermarket ones.
As for the speedo, I am going to see if I can somehow get around the one I have. For now I am just using my laptop with GPS mapping software to tell me how fast I am going.
One more pic:
CB
Old Jul 15, 2009 | 11:40 AM
  #1469
liljap215's Avatar
with the new swampers
[IMG][/IMG]
[IMG][/IMG]
Old Jul 15, 2009 | 02:31 PM
  #1470
JoKEpLaYeR's Avatar
Finally found a weekend to wrench and look what happened!
Old Jul 15, 2009 | 02:40 PM
  #1471
mattaway's Avatar
love the 4.3 man. looks like you did a pretty clean swap. what tranny did you use?
i'm kinda planning on a 4.3 swap, any advice?
Old Jul 16, 2009 | 04:40 AM
  #1472
TPLefever's Avatar
I'm not sure I put these snow pictures up from March, with the new chrome lower valance and showing some flex. ;-)
I've got better pictures of flex, but it's kind of hard to get hold of those pictures when they're on the opposite side of the world.
Old Jul 16, 2009 | 04:58 AM
  #1473
cblackard's Avatar
Kept the stock transmission and transfer case. They are quite capable of handling the output from the 4.3, so I didn't see a need to change them. Had I stepped up to a V8, then I might would have thought about changing to a GM tranny and x-fer case.
Best advice...Keep your CPU. Here is a list of what I purchased to get mine going as a carburetor fed engine. (fuel injected will need the Chevy CPU in conjunction with the Toyota one)
1. 1996 - 4.3 Vortec (rebuilt stock with an eldebrock alum. intake)
2. Downey Off-Road adapter kit that included or purchsed along with:
Bellhousing adapter for the Toyota transmission
Clutch slave cylinder
Motor mounts
Transmission adapter mount (for the crossmember)
Clutch and pressure plate (pilot bushing and throwout bearing)
143 tooth flywheel
Temp and oli pressure sending unit adaptors
Alum. Radiator
All the nuts and bolts necessary for the conversion
3. High torque starter for a 143 tooth flywheel
4. Aftermarket HEI Distributor for the 4.3
5. Aftermarket electric fuel pump (low pressure unit for carb)
6. Duel exhaust with knockoff FlowMaster muffler
7. Various belts and hoses to adapt to the radiator, heater core, etc...
8. Barry Grant Demon Carb (525 CFM)
9. Power steering pump, Alternator & A/C Comp (didn't come with the 4.3)
All of the little things needed to adapt the throttle linkage, vacuum lines, power steering lines, etc were home made or home brewed adaptors (non kit).
Re-routed alot of the wiring to match up to the new configuration.
I did have to cut and modify the thermostat housing to adapt the stock one to the intake. It pointed in the wrong direction when mounted as is. I just cut it and rewelded it to match up with the stock 4.3 hose which worked great.
I also used a low pressure electric fuel pump instead of using a high pressure one with a regualtor. Its just a preference but you could go with the regulator especially if you use the stock fuel pump (mine was toast from sitting too long dry)
If you are going to use the fuel injection then the above mod is not necessary since you would be using the stock intake. This is where the GM CPU will be required. My understanding is that you leave all of the sensors and such intact and add the Toyota temp and oil sending units using the supplied adaptors from Downey to connect to the Toyota CPU. The GM CPU will use its sensors to keep the engine running properly, while the Toyota CPU is strictly for monitoring Oil, temp and keeping the speedometer working. I think for the tach, you would just splice it into the signal from the GM CPU and it should work. The fuel sending unit does not require the CPU to work the guage.
That is kind of an abreviated version of the build. It wasn't too complicated once I got a few pointers from a mechanic friend of mine. He was a big help when it came to getting the wiring adapted and the actual rebuild of the engine.
Old Jul 16, 2009 | 02:42 PM
  #1474
mattaway's Avatar
thanks, cblackard i'll keep all that in mind.
i've got an '89 4x4 s10 with a blown 4.3 that i would love to build a 350 for and leaf spring it with 1/2 ton or 3/4 ton chevy running gear. (i'm trying to find a cheap suburban, i like the old pickups and k5 blazers too much to hack up) if all that works out and my 'yota keeps acting the way it is i'll build up a carb'd 4.3 for it.
i'm glad the stock toyota tranny and t-case hold up good with a 4.3, i'd like to keep the 700r4 in the s10, and keep the yota 5spd.
ok now back on topic
Old Jul 17, 2009 | 03:43 AM
  #1475
flashkl's Avatar
Thats a pretty comprehensive list of 4.3 swap stuff for a single post. I'll have to keep that bookmarked for the day my 3.0 falls apart.
Old Jul 17, 2009 | 10:40 AM
  #1476
shftatsix's Avatar
sorry for the cellphone pics but:
Old Jul 17, 2009 | 10:47 AM
  #1477
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
Yep.. and its in the post your pictures thread...
Old Jul 17, 2009 | 02:26 PM
  #1478
mattaway's Avatar
cry about it....
Old Jul 17, 2009 | 06:45 PM
  #1479
YotaOfTheRockies's Avatar
Thumbs up 94 4Runner
Just grabed this 94 4Runner. New Trans and Drive shaft put in. 165 on the engine but still running strong!
Attached Thumbnails Post Your Pics!!!-100_0265.jpg   Post Your Pics!!!-100_0266.jpg
Old Jul 17, 2009 | 08:58 PM
  #1480
toylocost's Avatar
cry about it....
I dont give a crap wheather its here or not. Chevy can suck it as far as I'm concerned. But for people who are searching for info on this swap it would be beneficial to have it in its own thread. I would encourage the original poster to start a new thread with this info on it. I think it is good info that would be very usefull to others. Just would like to see it in a location where it could benefit more people.
