Post Your Pics!!!
Old Mar 21, 2011 | 05:05 PM
  #6881
drmix's Avatar
Originally Posted by Wheelindealin
Tried out my tires
[IMG][/IMG]
I would like to get a open filter intake like that but I would be worried about sucking up mud. Is there any way to cover the filter with something so it would harder for any water to get to it. Right now im just running stock
Old Mar 21, 2011 | 05:25 PM
  #6882
Lumpy's Avatar
Just don't go that deep..
Old Mar 21, 2011 | 05:30 PM
  #6883
weikel81's Avatar
i have a k&n drycharger filter cover that is water resistant and works really well at keeping the water out. check for your sizw here under drycharger http://store.knfilters.com/search/wrap.aspx
Old Mar 21, 2011 | 05:39 PM
  #6884
drmix's Avatar
The dry charger filter looks pretty good. Ill probably get one if I get upgrade the intake.
Would one of these be any good? It doesnt really tell you what the case does
http://cgi.ebay.com/S-B-75-9006-Cold...item4838df2708
Old Mar 21, 2011 | 06:40 PM
  #6885
Wheelindealin's Avatar
Thanks guys.
And you can just put a shield infront/beside the filter to minimize the water comin through the grill and underneath
Old Mar 21, 2011 | 06:41 PM
  #6886
Which technically makes it a "cold" air intake then
Old Mar 21, 2011 | 06:51 PM
  #6887
drmix's Avatar
Not sure but maybe because it has the opening on the front of the box so that it only sucks in the cooler air flowing through the grill rather than from the warm engine compartment
Old Mar 21, 2011 | 07:26 PM
  #6888
laskt9's Avatar
its not a cold air intake. that term has become so generic anything with an open filter is called that now. technically its a short ram or hot air intake.
Old Mar 21, 2011 | 09:26 PM
  #6889
yeehaw1's Avatar
Tryin to get 60/40 seats installed and run some amp wire earlier today.
Old Mar 22, 2011 | 07:21 AM
  #6890
tlrskunk's Avatar
Posr pics/ Flex test with the fork lift at work after new shock hoops and Rancho 9012's (picked up on Craigslist for $20) Installed.
I work at a fab shop and my brother is a welder here. so we welded up the hoops at work.
Old Mar 22, 2011 | 08:23 AM
  #6891
MT YOTA's Avatar
Originally Posted by T.O'Brien
OOOO.....Purdy I'm jealous.
That looks so much better than the before pic. Keep it looking nice!
Thanks! I plan to keep It pretty much stock. Deluxe ARB bullbar is in the works since I live in deer central. And hopefully some toyo a/t's soon.
Old Mar 22, 2011 | 08:26 AM
  #6892
highonpottery's Avatar
^^nice! looks like it's time to bust out the grinder on those wheel wells.
Old Mar 22, 2011 | 08:29 AM
  #6893
tlrskunk's Avatar
The part that is black will be getting cut out and plated Flat here in the next few weeks. that is my fix for the pocket rust that is bad on the other side
Old Mar 22, 2011 | 05:24 PM
  #6894
az_eaglescout_pilot's Avatar
I put my new intake on yesterday too.
Size:  187.5 KB[/QUOTE]
whats the clearance between the master cylinder and the elbow??? it looks like its touching and thats gonna rub right through that plastic intake elbow...
also can you still get to your oil dipstick ( on the truck...)
Old Mar 22, 2011 | 06:12 PM
  #6895
Eaglescout,
Its not touching, just close. And yeah there is no obstructions to the dip stick. It aluminum too no plastic, just rubber boots. the whole kit fits ok, just had to turn the maf a little to not be against my distributer
Old Mar 23, 2011 | 05:15 AM
  #6896
shaunneuhaus95's Avatar
the twins
these are my babies, red 1 is 94 3slo 172k, blue 1 is a 92 3slo 233k and climbing
Old Mar 23, 2011 | 02:20 PM
  #6897
I know mines not a "cold" air because the filter is exposed to the engine bay still. So yeah u could call it a ram air or just high flow intake and filter i guess.
Old Mar 23, 2011 | 05:17 PM
  #6898
benelli's Avatar
Heres my little piece of junk
Old Mar 23, 2011 | 05:44 PM
  #6899
Black_1985_SR5's Avatar
Mud is the best paint job
Old Mar 23, 2011 | 06:00 PM
  #6900
ZAP Toyota's Avatar
94 sr5 4runner bone stock except for different 3.0 v6 and K&N Air Filter
