post diff drop vibration
Old Feb 6, 2007 | 04:56 PM
4rockclimber's Avatar
From: From San Francisco, but attending school in Pomona CA
a little bit of background first
its a 1990 4runner 3vze 192100 miles
front: 1.5 bj spacers, aisin manual hubs
rear: crusier coils, panhard drop yada yada
33/12.50 bf goodrich mts that are torn up and out of round
just removed the front sway bar and installed a 4crawler 1 inch diff drop
now at about 15mph there is a loud rattle a lot of vibration and the ocasional grinding feeling that all goes away as i speed up
the hubs are still engaging/dis engaging smoothly
lifted the front off the ground.. tires spin smoothy and there is no back and forth wheel movement that would indicate a bad bearing.. also the hub is warm after driving... not hot
the suspension cycles smoothly without rubing the tires
i cant figure it out.. my best theory is that im just noticing more of the tire vibration because there is a block of aluminum between the diff and the frame.
please gods of yotatech.. guess away.. any ideas you can give me would rock
Old Feb 6, 2007 | 04:59 PM
Stomis's Avatar
Hmmm I think I have the same problem. Do you get it when acceling in reverse and braking hard? What I've been hearing you can only hear from the cab (my dad stood outside and couldnt hear it outside the vehicle when it was very loud inside). It almost sounds like metal scraping on metal but its a very odd noise. Its almost like my cab is amplifying it from the sheetmetal picking the vibration up...
Old Feb 6, 2007 | 05:01 PM
i definately get it when slowing down more than accelerating.. but it makes no difference if im on the brakes or downshifting.. always at 15mph
Old Feb 6, 2007 | 05:15 PM
fthertime666's Avatar
some thoughts... are the diff assembly mounts oval shaped (slop in the mount bracket) that would be used (by service personnel) to align ujoint and cv joint tolerances?
Old Feb 6, 2007 | 05:24 PM
i dont believe they are
jerusry
Oct 19, 2015 05:28 PM
jaretstuff
Aug 4, 2015 02:08 PM
coffey50
Jul 28, 2015 10:55 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
scottyg486
Jul 19, 2015 05:34 PM
