pooched and STUCK zerk .... hep me hep me !!
Old Jul 28, 2008 | 07:39 PM
reedtree61's Avatar
one of my grease zerks has decided to go south on me (ie it won't hold grease in; it would seem i've lost my ball ) so i figured "no biggie", i'll just replace it ... WRONG ... she's good and stuck; does anyone know if they're just press-in fittings, or are they threaded. ANY help would be more helpful than the smartass remarks coming my way right now. thanks
Old Jul 28, 2008 | 07:40 PM
TOYOTA 1's Avatar
they are threaded.
Old Jul 28, 2008 | 08:32 PM
muddpigg's Avatar
If you shear the zerk off, an easy out works like a charm getting the remainder out.
Old Jul 28, 2008 | 10:47 PM
Matt16's Avatar
Your not supposed to use a Lance Armstrong zerk, that's your first problem.
Have you tried heat, penetrating oil (PB Blaster), tapping it with a hammer lightly then vice-grips?? It would help to know which zerk.
Old Jul 29, 2008 | 04:23 AM
dirtoyboy's Avatar
x2.....
Old Jul 29, 2008 | 05:47 AM
Crawdad's Avatar
They are threaded, a 10 maybe? Or an 8?
Old Jul 29, 2008 | 05:52 AM
dirtoyboy's Avatar
I'm pretty sure they are 8mm heads but the zerk itself is M6x0.75 fine thread
Old Jul 29, 2008 | 07:00 AM
CJM's Avatar
CJM
Heat and an 8mm should do it.
Old Jul 29, 2008 | 09:28 AM
reedtree61's Avatar
it's out
thanks for everyone's input; thinking about the heat thing, i realized it's just a temperature differential thing between the 2 metal parts, so i tried freezing the fitting with an inverted can of electronics duster ("canned air"); worked like a charm; it just about fell out. thanks again everyone
Old Jul 29, 2008 | 10:34 AM
axekick's Avatar
Dude, good thinking! I'll use that sometime.
Old Jul 29, 2008 | 10:39 AM
CJM's Avatar
CJM
Good trick too, they sell a spray called freeze off that does the same thing
Redeth005
Jun 28, 2018 08:16 PM
rubrsidedwn
Jul 7, 2016 07:28 PM
spiewaker
Dec 16, 2015 01:10 PM
BK2TFUTURE
Oct 11, 2015 08:42 PM
Obmi
Sep 24, 2015 08:10 AM
