please help i put k&n on and blow efi fuse every time i try to start truck
Old Nov 4, 2009 | 04:56 AM
robert1965's Avatar
my truck is a 93 4x4 22re. i mounted a k&n on the throttle body, the plug that connects to the mass air sensor has many little pins on it. when i plug it back in and try to start the truck it acts like it wants to start for a second but does not, it keeps blowing efi fuse under the hood. im wondering if i bent one of the pins on the plug that connects to the mass air sensor etc. thanks for any help
Old Nov 4, 2009 | 04:59 AM
Junkers88's Avatar
What did you do about the AFM on the airbox if you mounted an air filter directly to the TB?
Old Nov 4, 2009 | 06:10 AM
ozziesironmanoffroad's Avatar
are your wires screwed up?
Old Nov 4, 2009 | 06:28 AM
Robert m's Avatar
there is your problem. put the stock intake tube, filter box, and AFM back on the truck and take the cone filter back to where ever you got it from. if you feel the need to run a k&n filter still, buy the flat replacement filter that goes in the box. your not going to gain anything from it either way though.
Old Nov 4, 2009 | 06:56 AM
Marc's Avatar
When you removed the plug did you remove the clip or the screws to take it off.
If you removed the screws it is now broken.
Crazychris1871
Jun 27, 2016 10:38 AM
Alex Bessinger
Jun 28, 2015 10:05 AM
odonekanobe
Jun 26, 2015 02:27 PM
torgeir
Jun 25, 2015 05:26 AM
94 First Responder
Jun 6, 2002 02:19 PM
