PLEase help 1990 truck 22re power loss please help
Old Sep 12, 2012 | 04:10 PM
Brandonn Mixon's Avatar
hi i have a 1990 22re built with a soild axel swap and leaf spring swap with 40 in tires
i drove it home the other day and started lossing power and vac leak
replaced all vac line, fuel filter,intake,maf sensor,distubitor,cap rotor,and coil
truck at start up runs fine and idles pefect at 900 rev it it bogs down a bit then pics up then you drive it down the road and thiers no power at all it takes 5 min just to get to 3k rpm just cant figure it out
btw if you unplug the tps sesor the truck runs the exact same not a change with or with out it thoughts thanks for your help
Old Sep 12, 2012 | 04:16 PM
swampfox's Avatar
It might be a restriction in the exhaust system.
Old Sep 12, 2012 | 04:29 PM
to be honest with ya it has a header and then a small pipe back to a muffler it does have a exaust leak tho thoughts
matrad
Aug 26, 2024 08:21 AM
zd92655
Mar 6, 2022 12:58 PM
DacodaYota
Sep 2, 2015 02:13 PM
rbravo1
Jun 29, 2015 01:34 PM
RTdawgs
7
Jun 16, 2002 06:37 AM
