Pitman Arm stuck
Old Feb 5, 2010 | 08:32 AM
InternetRoadkill's Avatar
Thermite, FTW
Old Feb 5, 2010 | 09:06 AM
swampfox's Avatar
try cutting a relief in the arm.just don't cut into the splines.if it still won't let go put a chisel in the cut and hit the damn thing. that has worked well for me.
Old Feb 5, 2010 | 12:17 PM
crafthorse's Avatar
I have absolutly nothing to add to this thread that would help you, it has been covered over and over, Tension, Mini Sledge Wacks, and it should pop off. You have already covered the lubricant portion. If you do need heat, it should not take muck more than just knocking the chill off the idler arm around the shaft.
aowRS
Sep 13, 2017 08:22 AM
pickle6415
Dec 25, 2015 07:34 PM
Project90
Sep 24, 2015 11:40 PM
1965chevy
Sep 20, 2015 07:33 PM
JRB4Runner2015
Sep 20, 2015 12:29 AM
