pics of skid plates
since you're thinking of building your own soon...i had the idea of adding a 2" or so body lift to my truck so that i could raise everything but the axles and driveshafts above the bottom of the frame rails. This would allow for a bellypan to bolt to the bottom of the frame rails covering the area between the two driveshafts..sort of what the buggies have but on a truck.
How does raising everything up correlate with the motor. Do you need to add spacers in the motor mounts to?
x3 www.budbuilt.com They make some STOUT stuff and you can get them made for a drivetrain lift.
took a regular skid, cut off the old sheet metal and welded on some .25 steel.
I plan to make one to cover the bottom of the diff as soon as I buy a Sonoran
steel IFS brace. The downey brace I have makes removing the diff VERY difficult.
I saw a crossmember that's exactly like the budbuilt but for $195 from www.trail-gear.com ... anyone use that one?
I paid a little over $500 for the front skid, crossmember, and belly pan. Have you priced steel lately? I didn't think it was worth trying to build them. Also, if you can swing all of them at the same time Bud will normally cut a deal on them.
