Painting soon, any quick avdice
Truck will be ready for paint this week, anybody have some words of advice or simple things i should know, this is going to be my first paint job.
thanks
thanks
You gonna be spraying it yourself ? In my opinion paint jobs are 80 percent prepwork and 20 percent spray work. After your primer coat spray a guide coat and block it out to find high/low spots and re-prime it and repeat if needed. WEAR A PAINT MASK and wear long sleeves as iso's absorb through the skin as well. before the basecoat wipe the body down with a wax and grease remover ( i use rubbing alcohol) then wipe over with a tack rag and lay down a coat of base alnd let it flash and re-tack before you spray the clear coat (don't try to tack the clear) i usually lay down 3 wet coats of clear and that allows me enough to wetsand and buff. oh yeah read on the cans for the proper flash time and go by that as you don't want any solvents popping through the clear
highway
highway
thanks alot highway, ya i am going to spray it myself, i have put about 60 hours into prep work, i am making sure everything is perfect before i start to paint
just a few questions
what is a tack rag? where can i get some?
what is flash? (time to dry?)
and should i spray on numerous clear coats without letting them dry or one at a time allowing them to try inbetween?
Thanks again for the help
flash- usually 15 minutes the can should say. the flash time allow the solvents to dry out between coats and helps avoid runs in the paint, if you don't allow enough time th epaint stays to wet and you will get some sags/runs. thats no problem in the base because you can sand them out after it dries for a bit and lay down another coat.
As far as the clear that sorta for me depends on the work/dust enviroment. if you are using a booth then shoot the coats of clear after the proper amount of flash times i put on my 1st coat of clear just like i do my last ....wet, the days of tack coats are long gone in fact those who start with a tack coat in clear will start with more orange peel. if you do get dust in the clear you can always stop and wetsand the next day and shoot a couple more coats of clear or if afterwards the dust is minimal then you can let it sit overnite and wetsand with some 1500-2000 grit and buff it out
also you may want to read this for the gun setup: http://www.autobody101.com/articles/...%20Atomization
usually if i get a run , after it dries i take a single edge razor blade and scrape the run backwards which shaves off the run a little at a time and when i get it close finish up with sandpaper 1000 grit and upwards to 1500 grit and buff them out.
highway
highway
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
zytra
Jan 24, 2019 03:16 PM
charlie_fong
Sep 27, 2015 10:06 PM
