Overheating after engine rebuild, Please help!
better test for the clutch. It can go bad in two ways, i would know. Replaced mine after engine rebuild and i had a stuck clutch that would not disengage causing a whirr during accel and heavy hard shifting. Honest.
If you cant spin the fan at least a quarter turn while the engine is off. Its like mine (after warm up of course) If that works, and the car is good and hot, take a balled up rag and gently press it to the edge of the fan. If it stops before tearing your hand off ( Obviously) ur clutch is no good andit's not engaged fully when it needs to be. (when engine is Hot) good luck
Hey everyone, I just moved into my new house in Colorado Springs and have been super busy in the last couple weeks. Thanks for all the responses. The problem with the overheating turned out to be a cracked radiator cap.
jerusry
Oct 19, 2015 05:28 PM
Avenged
Jul 9, 2015 07:55 AM
