over heating problem
Old Dec 20, 2007 | 09:51 AM
beerbottle81's Avatar
I gotta 22re that over heats when i first go and drive it for a bit then after that it's fine even when I let it idle forever it doesn't over heat. Temp sensor faulty? I had a problem with it not reading so I replaced it with my old one of another engine and the gauge started working again. I also replaced the thermostat cause it was bad. I've heard of a two stage thermostat from the dealership that's suspose to be better than aftermarket in terms of over heating. I also don't have the fan shroud for the radiator but I'm not sure if that'll make any difference. Any input would be greatly appreciated. THANX!
Old Dec 20, 2007 | 10:36 AM
Luvmeye22re's Avatar
A lot of times overheating under load or highway speed only can be a symptom of a radiator that is starting to clog.
Old Dec 20, 2007 | 11:23 AM
Thanx for tha reply but the raidator i have is brand new. Anyone else?
Old Dec 20, 2007 | 11:28 AM
Kaydon's Avatar
Did you check your hoses?
Old Dec 20, 2007 | 11:39 AM
for clogs? not yet maybe I should flush the whole engine out. It was a new motor I put in. I know the guy said it's been sitting around for a year or so. Thanx maybe i'll do that see if it helps.
Old Dec 20, 2007 | 11:57 AM
MMA_Alex's Avatar
fan shroud will help a lot with idling and low speed. if you can see crap in the radiator floating, or the coolant is more than a couple years old its worth doing a flush & refilling it.
Old Dec 20, 2007 | 06:31 PM
mt_goat's Avatar
http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
PlayAwhile
Jul 20, 2015 11:36 AM
jjrbus
Jul 19, 2015 02:06 PM
the1998sr5
Jul 16, 2015 06:20 AM
