One-eyed monster: sealed beam question
Old Jan 10, 2009 | 07:26 PM
  #41
Matt16's Avatar
Originally Posted by 86tuning
Hella h4 conversion is european code, which is 100% legal in all of Canada.
You'd be very happy with them. I put them in all cars that fit 6054 lamps.
I'll look into it this summer when I'm doing less school, more work. Can you still see non-illuminated overhead signs (ie: BC Ferries) with the low cut-offs?
Old Jan 10, 2009 | 08:27 PM
  #42
Jay351's Avatar
Originally Posted by Matt16
Osram is the same company as Sylvania, though I've seen some stuff labeled Osram and some labeled Sylvania.
Osram ownes sylvania. But they make a seperate Osram silverstar bulb. Its MUCH better then the sylvania version. Google it, I found it out when I was researching the silverstars lifespand and wetweather performance.
p.s
How do you like your yellow fogs? I really want to install a similar set..
Old Jan 10, 2009 | 08:39 PM
  #43
86tuning's Avatar
You can see everything. I'll show you when we hook up to go fishing or 'wheeling lol.
Old Jan 11, 2009 | 12:25 AM
  #44
Matt16's Avatar
Sounds good. My Nighthawks (edit: Nighthawk, singular, only bought one to replace the burned out light) are actually way brighter than stock. Not bad for an extra $15 compared to the standard GE sealed beams. Strangely, what was a good aim on the old headlights was completely off with the Nighthawks.
Old Jan 11, 2009 | 01:25 PM
  #45
Jay351's Avatar
Hey Matt, You can defantly see the overhead signs on the hwy. Its not as bright as if you had DOT lights but the added light on the road really helps. Its nice when you want to see a roadside sign. The flared pattern lights up the signs really well.
let me know if you want to see how they look....
Old Jan 11, 2009 | 07:51 PM
  #46
Bako88's Avatar
Matt, did you use a floor jack to replace your headlight? I see it in the photo you posted. If you have to jack a sealed beam into place, I take back what I said about you guys being tougher.
Old Jan 11, 2009 | 09:14 PM
  #47
Matt16's Avatar
Hell yeah, installing those headlights is hard on the back.
TJWilly
Jul 31, 2015 02:05 PM
msane99
Jul 27, 2015 06:14 PM
colasurdo
Jul 16, 2015 11:32 AM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
