Oil Pan Gasket/Rear Main
Old Aug 5, 2008 | 07:00 PM
Jay351's Avatar
No need to reef on the oil pan bolts. Just watch the gasket. Truck has been running great with 0 oil leaks since we did it a few months ago.
Im glad that cv stuff made sence Jason, though I have no idea what this speedy sleeve thing is you talk about
Old Aug 6, 2008 | 05:38 AM
jason191918's Avatar
I have the black silicone. Is that RTV?
The speedy sleeve is a sleeve that goes over the crank where the rear main seats, so it seals where the grooves are worn into the crank.
Old Aug 6, 2008 | 11:21 AM
wolviak's Avatar
Originally Posted by jason191918
3. My oil pan gasket came in yesterday. There are 2 identical cork gaskets in the box. Why?
Thanks ahead of time.
I'm doing the same job you're doing right now. There's two gaskets because there's a plate (might be a crank scraper) between the engine internals (crank, rods, etc.) and the oil pan. You'll see it once you drop the pan. To remove the plate, you have to pull the oil pump pick up tube. Unfortunately my gasket set didn't come with a new gasket for that. I've been trying to locate one, but have had no luck. It looks like I'll be making one myself.
Old Aug 6, 2008 | 12:24 PM
Thanks for the input.
Old Aug 6, 2008 | 06:33 PM
  #25
Cyberman's Avatar
Ya, the 3VZE has a baffle plate between the block and the oil pan.
Old Aug 22, 2008 | 09:36 AM
  #26
Day 1 (4 hrs)=clutch slave, starter, front/rear driveshafts, t/case/tranny shifters, tranny, clutch, and flywheel off.
Old Aug 22, 2008 | 05:24 PM
  #27
Jay351's Avatar
Sweet! Good luck on the install
Old Aug 25, 2008 | 09:32 AM
  #28
Day 2: Front Diff lowered and am starting to take oil pan off. Ordered oil strainer/pick up gasket that won't be in til wed......doh!
Old Sep 25, 2008 | 08:08 AM
  #29
So I guess I forgot to update this....
A few days later, I had 'er all put back together. I have since done the valve cover gaskets. I think the only other leak now is the oil cooler. I have parts comin' in today and then I think the gross polluter will be leak free (well as far as oil goes...)
dumpster84
Apr 30, 2016 06:03 AM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
irritech
Jul 27, 2015 05:15 PM
88yodabasket
Jul 13, 2015 01:32 PM
