oil gauge being wierd
Old Feb 18, 2009 | 03:40 PM
1stgen4gunner's Avatar
hey guys,
have a question, my oil level gauge on the dash is acting up, It right now reads that I have almost no oil at all, when I give the truck some gas it shoots up to the quarter way mark, I let the truck sit a bit after I got home and checked the dipstick, oil level is fine, the truck isn't overheating, idles great, sounds great, everything is working as it should, except the gauge was still reading very low, could this be the oil pump? No check engine light is going on, so I can't have the convenience of codes, reset the ECU? I don't know, what do you folks think
Old Feb 18, 2009 | 04:19 PM
bump please
Old Feb 18, 2009 | 04:46 PM
Wow does nobody know?
Old Feb 18, 2009 | 04:56 PM
GSGALLANT's Avatar
Well... sometimes it takes more than an hour to get an answer...
First of all, you don't have an oil level gauge on your truck... you have an oil pressure gauge. Since the oil pump is driven by the engine (rpm dependant), the higher the revs, the faster the oil pump turns, and the higher your oil pressure. What your describing is normal.
Old Feb 19, 2009 | 04:43 AM
Holy Crap I am an idiot. For some reason i was under the thinking that the oil pressure gauge in my truck measured the oil level. My pop came home last night after using it (and I stayed up all evening worrying about it, especially after it started snowing, and wondering whether he knew how to use manual locking hubs) and told me my oil level was low, but it looks OK when I started driving it this morning after I reset the system.
bigjstang
Jun 2, 2025 03:56 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
88yodabasket
Jul 13, 2015 01:32 PM
