Oil change 22re
Old Mar 13, 2008 | 04:28 AM
ozziesironmanoffroad's Avatar
big pita i agree with the PO
Old Mar 13, 2008 | 04:49 AM
MMA_Alex's Avatar
Originally Posted by deyodragon
I was just gonna suggest the Fram PH8A myself! I got a tough guard (or is it the extra guard?) , with internal valves to keep oil in the filter for well lubed starts. More filter, more oil, same threads and gasket. Can you beat it?
yes, you could buy anything but fram. many for the same price, all with far superior performance...
ps. every oil filter has an antidrainback valve like you describe, but fram's doesn't seal very well. everyone else's seems to do just fine...so much for no dry starts.
Old Mar 14, 2008 | 05:25 PM
Georgiadave's Avatar
You might consider a remote filter kit, it the present location is that difficult for you, or you don't like the oil leaking on the block and crossarm. If the filter is on too tight, wrap a strip of sandpaper about 3 X 8 long around the filter, it will give you more grip to turn the filter by hand. Unless you have very big arms, you should be able to access the filter from directly in front of the battery.
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
horunner1x
Jul 10, 2015 06:33 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
HRDC0R19
Jul 5, 2015 06:43 PM
