Octane rating for 12 to 1 compression ratio 22r?
Old Mar 23, 2023 | 02:36 AM
JUN670's Avatar
Hello, I’m building a 22r and planning to go with a higher compression ratio (12 to 1) and was wondering what octane ratings I need for that much of a compression? We only have pump gas available (91) but I found race fuel concentrate that I can mix to bring it up to 100-105 octane. Will this be enough?
Old Mar 24, 2023 | 06:18 AM
Robert m's Avatar
Is this for a street engine or race?
I'd start with 91 and play with the timing and see if it pings.
Old Mar 29, 2023 | 01:28 PM
JUN670's Avatar
Yes it is used in the streets but barely, it will mostly be used for drags. As of right now I use 10.5 to 1 compression ratio with 91 octane and it does ping at times so I dialed back timing. Was thinking to use that race gas concentrate to build a 12 to 1 stroker build or else I’m just gonna have to use a 10 to 1 stroker motor.
crjosh97
Jun 25, 2016 03:10 AM
nacy369
Jun 21, 2013 10:07 PM
Diff Cranker
Mar 30, 2011 05:54 PM
lilred61287
Jan 27, 2009 06:25 PM
