normal auto slugg or did i do something wrong
Old Dec 14, 2008 | 06:39 AM
Dan.3's Avatar
disconnect the shift selenoid harness. This bypasses the the selenoids and allows you to shift manually. L is 1st 2nd is 2nd and D is fourth. If it drives fine with the selenoids unplugged then it is an electrical problem.
Where was it rebuild? Honestly I would rather have a used higher mileage toyota trans than a rebuilt one. Few places can actually rebuild a toyota trans in the US. If its not an electrical problem take it back to whoever rebuilt it and and tell them to do it right or get your money back. good luck
Old Dec 14, 2008 | 07:26 AM
Team420's Avatar
hmmm...an auto with 4.10's in a runner???? should be 4.30's or 4.88's...shouldnt they?
Old Dec 14, 2008 | 07:28 AM
Team420's Avatar
Originally Posted by JoKEpLaYeR
Hum, we were taught to check it in Drive in auto shop many years ago. But I'm no auto tranny expert.
That would be for SOME chrysler and jeeps....
Old Dec 14, 2008 | 07:56 AM
FredTJ's Avatar
NO that wouldn't be for anything.
Some Chrysler's (including the TJ jeeps) require the tranny to be in NEUTRAL not in drive, to check the fluid level. That would be a huge safety issue.
Fred
Old Dec 14, 2008 | 07:58 AM
  #25
FredTJ's Avatar
Originally Posted by BAMF_CT2004
<SNIP>
Few places can actually rebuild a toyota trans in the US.<SNIP>
Pure bull poop
There is nothing special about these trannies.
I saw and re-built them fairly frequently when I owned the tranny shop for years.
Fred
Old Dec 14, 2008 | 08:13 AM
  #26
Team420's Avatar
^^ x2.... they are the same thing as the jeep 4.0 trannies...are they not?
O ya...duh...sorry, I knew that about the neutral thing...lol
Old Dec 14, 2008 | 08:19 AM
  #27
FredTJ's Avatar
They were used in the Jeep Cherokee's (XJ's) with the 4.0.
The exact same tranny.
Fred
Old Dec 14, 2008 | 08:29 AM
  #28
91 4Runner's Avatar
That's a popular misconception. Mine is 3.0/Auto/4.10/ 215/75R15.
Old Dec 14, 2008 | 08:37 AM
  #29
91 4Runner's Avatar
Sorry that was supposed to read 225/75R15 but for some reason I cannot edit - I get an error on page.
Old Dec 14, 2008 | 10:01 AM
  #30
Dan.3's Avatar
Originally Posted by FredTJ
Pure bull poop
Fred
you are correct.
what i meant to say is that there are probably very few shops in the US than can rebuild it CORRECTLY. I could rebuild a 340h if I wanted to. Odds are it wouldnt be correct though. Would you take a 22r or a 3vze to and shop to be rebuilt? I wouldnt.
Old Dec 14, 2008 | 11:32 AM
  #31
Tofer's Avatar
Sponsor
.... then it is an electrical problem.....
thats seems to be a theme with this truck...
just replaced the driver side window swithc because the window wouldnt roll up.... now if you press the door lock button nothing happends, the window lockout switch turns the clock off and on. the driver window up doesnt do anyhting, driver window down locks the doors, pass window down doesnt do anything pass window up will unlock the doors but only if you at the same time press the window lock out button again (and trun off the clock) if you dont press the window lockout at the same time it doesnt do anything.
Old Dec 14, 2008 | 11:46 AM
  #32
Dan.3's Avatar
i would disconnect the selenoid harness for the trans just to be sure. What happens if you put it in L?
Old Dec 14, 2008 | 12:13 PM
  #33
Tofer's Avatar
Sponsor
R and L work fine.
Old Dec 14, 2008 | 06:05 PM
  #34
FredTJ's Avatar
<SNIP>
what i meant to say is that there are probably very few shops in the US than can rebuild it CORRECTLY. I could rebuild a 340h if I wanted to. Odds are it wouldnt be correct though. <SNIP>
Simple nonsense.
There is NOTHING special, weird, requiring special sauce or anything else really odd about these trannies.
It's a straight forward little tranny that isn't a big deal.
For the life of me I can't understand why you think differently.
We've rebuilt CORRECTLY a good handful of 'em in my shop.
As you probably know (not ), they aren't even a Toyota tranny, but rather an Isuzu tranny, properly called the AW30-80 LE....
The AW30-80LE is a rear wheel drive, four speed, electronically controlled transmission.
Internal components consist of a lock-up TC, oil pump, 5 multi-disc clutch packs, 1 brake band and three planetary gear set. The valve body includes electronic solenoids for shift control that are controlled by a TCU. A throttle cable is used for line pressure control.
Sure..
Why not ?
People do it all the time.
Nothing magic about either of those engines either.
Fred
Old Dec 14, 2008 | 07:29 PM
  #35
scuba's Avatar
Time for a 5speed swap buddy
Old Dec 14, 2008 | 08:17 PM
  #36
881stGenRunner's Avatar
just as someone suggested, take the trim off that is around the shifters and you will find the TCU. Disconnect the TCU and from then on, L-1st, 2-3rd, and D-4th without TC lockup.
you will no longer have 4L unless you put the truck in 4L with everything completely off and then cranking it back up.
Old Dec 15, 2008 | 07:30 AM
  #37
InternetRoadkill's Avatar
I rebuilt my 340H including the xfercase and I'd never rebuilt an auto tranny before. Works perfectly. You just need a clean space, a good manual, and some patience.
Old Dec 15, 2008 | 08:34 AM
  #38
Jay351's Avatar
wow, props to you! I looked at the autotranny rebuild section in my FSM. That bastard must be 100pages long, give me a 5sp anyday
Old Dec 15, 2008 | 11:23 AM
  #39
You know the hardest part of rebuilding the tranny was overcoming the notion that autos are hard to rebuild. I've heard that time and time again. The fact is it wasn't that bad. If you can rebuild a motor comfortably, chances are you'll find rebuilding an auto not very difficult. There are lots of pieces to be sure. But it's just a matter of keeping things organized and being methodical in your work.
Jun 1, 2021 01:51 PM
jetpilot
Aug 15, 2015 06:48 AM
1996Taco
Jul 20, 2015 12:02 AM
andrewtexas123
Jul 14, 2015 04:29 AM
smiley52
Jul 11, 2015 05:16 AM
