noise from timing cover?
Old Jan 29, 2007 | 01:28 PM
saleen9973's Avatar
hey guys i noticed the other day that sometimes i hear a grinding noise coming from the timing cover area. It almost sounds like the belt or one of the cam sprokets grinding on the cover. Has anyone had this problem? It doesn't happen all the time. Any sugestions? Sorry motor is a 3.0.
Old Jan 29, 2007 | 01:33 PM
ChickenLover's Avatar
Assuming we are talking about the 3.0, there are two idler pulleys and a water pump behind the timing cover. The bearings in these pulleys will eventually wear out. It would probably be a good idea to remove the cover and have a look around.
Old Jan 29, 2007 | 04:00 PM
saleen9973's Avatar
sorry yes it's a 3.0.
Old Jan 30, 2007 | 03:25 AM
chopitrakeit's Avatar
timing noise
I have also heard noise under the cover from a piece of the belt coming loose and slapping or rubbing the cover. It would come and go at first, then was constant. The truck ran for a while like that then the belt was changed when the head recall was done.
Old Jan 30, 2007 | 01:34 PM
saleen9973's Avatar
i am going to have the t blet replaced on sat. I called toyota and they had no record of a timing belt being done before. The motor has 151,000 miles I found out that the head gaskets were done in march of 1998. almost 10 years ago.
msane99
Jul 11, 2015 08:08 PM
colinmil
Jul 6, 2015 04:03 PM
karbin
Jul 5, 2015 11:37 PM
