No more Yota
Old Dec 21, 2008 | 06:25 PM
  #81
Beaniam's Avatar
more pictures and stuff
put a lockright in my spare 4.88 v6 third and put it on the housing, got the knuckles shimmed and on (rock ring felt guards don't like to clear the creeper knuckle gussets without some trimming), hubs on, painted, tie rod on.
Old Dec 22, 2008 | 07:08 PM
  #82
Beaniam's Avatar
Made decent progress today for working alone and having never done this before.
Taking the obscenely heavy rockcrawler bumper off.
The mounting brackets are designed for IFS trucks, they're gonna take some heavy cutting and modifying to make work with the front spring hanger.
The remnants of the accident in the beginning of the thread. A ripple in the crossmember.
Heated up and pounded flat
Pittman arm which wasted a good hour of my afternoon.
Ready to start the cutting
Upper control arms unbolted and torsion bars cut and removed
Lower control arm brackets cut
Typical pile of IFS garbage. Some goodies in there though that will be for sale when I have time to tear it apart... Lock-right 4.88 v6 diff, 1.5" 4crawler bj spacers, ome steering damper less than 6 months old.
Time to start grinding
One side done and motor mount plate welded in. At this point after 13 hours I called it a day.
Old Dec 22, 2008 | 07:14 PM
  #83
waskillywabbit's Avatar
Getting so dirty was never so much fun eh?
I worked on my 85 ext cab Sunday afternoon in the first time in months...remembered why I loved this stuff.
Old Dec 22, 2008 | 07:33 PM
  #84
Beaniam's Avatar
Yeah look at the garage floor in the first picture and the last and that pretty much goes for me too.
Old Dec 24, 2008 | 09:58 PM
  #85
Beaniam's Avatar
Frame tubes, front hanger, front hanger to frame gussets idea that I stole from another yotatecher out of 1/4" steel, hung leaf springs, hung axle. 1am christmas eve, time to go to bed.
My broken rear leaf spring that gets ripped off tomorrow.
Old Dec 25, 2008 | 08:15 AM
  #86
I remember doing my lift on my 85 during the Christmas holidays a couple years ago...only free time I had. I'll probably be working on my 85 ext cab tomorrow doing the same thing.
Looking good!
Old Dec 25, 2008 | 08:30 PM
  #87
SwampThing's Avatar
Looking good dude.
Reminds me, I still need to trim my body mount...
Old Dec 25, 2008 | 09:38 PM
  #88
Beaniam's Avatar
Yup that's one of the many details left I am leaving for last. I just noticed I have a small chunk missing from the rear driveshaft yoke at the u-joint. I need to find another yoke, anyone got any spare driveshafts laying around they feel like pulling the slipyoke off and selling to me
Anyway made some more progress tonight. Ugh this is a hell of a lot of work for one person.
Suspension gone
Housing ground down
Gas tank drained and pull over out of the way of getting to the frame.
New spring perches on
Springs hung
Locating the spring perches on the housing and setting the pinion angle
Perches finish welded on
Sitting on it's new 4" springs
Old Dec 25, 2008 | 09:45 PM
  #89
sa51's Avatar
i'll take that ome steering damper off your hands, how much will u get rid of it for?
lookin good btw, it almost looks like it might be too tall..? when i swap a solid in, ima use 3 inch trail gear springs. cant wait to see the finished product
Old Dec 26, 2008 | 03:44 AM
  #90
nosfanatic2006's Avatar
I'll take the 4.88 lockrite diff . How much you want for it?
Old Dec 26, 2008 | 05:59 AM
  #91
Makes you appreciate it more.
You move the rear mounts at all?
Nice to see someone do it right by removing the rear spring perches and rotating the axle then welding on new ones. You will thank yourself later for sure.
Old Dec 26, 2008 | 06:21 AM
  #92
SwampThing's Avatar
^ I guess he took my advice, cause that's how I always do it.
Old Dec 26, 2008 | 06:42 AM
  #93
You'd be surprised how many I've seent that are not...and then they wonder why the rear d-shaft/pinion angle is crap.
Old Dec 26, 2008 | 06:56 AM
  #94
space-junk's Avatar
how do you know what angle to set the driveshaft at??
i mean, that looks heavily rotated, so just wondering when too much it too much...
Old Dec 26, 2008 | 06:58 AM
  #95
Shawn6string's Avatar
Smile bumper
Love the bumper. Where did you get it?
Glad 2 see you got it back together.
Old Dec 26, 2008 | 07:08 AM
  #96
If you will never go above 35" tire or you aren't worried about hacking the sheet metal and tubbing the firewall, then 3" springs are fine. Personally for a pickup, I like the 4" springs all around. Plenty of lift for bigger tires and it doesn't look out of balance with 35" tires.
Do like he did and put the springs on, put the axle back under it on the jack and then rotate the axle flange until it lines up with the rear output flange. A piece of string or eyeball it. You really don't rotate it but a few degrees, but it will make a difference and it takes so little time to do it right.
Old Dec 26, 2008 | 08:21 AM
  #97
SwampThing's Avatar
^ The only thing that doesn't fix is your tcase angle. Then you're looking at dropping the xmember for a few deg, moving the rear shackle mount, or swapping in or having a cv'd rear shaft made.
Speaking of which, you ain't got any rear cv shafts laying around for sale do ya brian?
Old Dec 26, 2008 | 09:27 AM
  #98
HiLuxer's Avatar
Nice progress. Keep it coming!
Old Dec 26, 2008 | 11:51 AM
  #99
Sorry Clint, but no.
Old Dec 26, 2008 | 03:08 PM
  #100
sa51's Avatar
all i want is 35s, on the same rims i have now. eventually i'd prob want 37s or 38s but thats a looong way down the road, by the time the 3 inch springs were worn out and sagging.
