no horn power at steering column
Old Jan 30, 2012 | 12:29 PM
mojo4x420's Avatar
Any hints?
The horn itself has 12v and works when I manually hook it up.
When I check at the steering column, neither the brass pin or the other wire has 12v.
I tried searching, but does anyone know any common problem spots where the wire might be broken between the horn and the steering column?
Thanks
Old Jan 30, 2012 | 12:50 PM
xxxtreme22r's Avatar
Does your 4ways work?
Old Jan 30, 2012 | 12:57 PM
angrybob's Avatar
Read this to see if it helps:
https://www.yotatech.com/forums/f116...y-help-239251/
Old Jan 30, 2012 | 01:06 PM
mojo4x420's Avatar
Thanks, but that link doesn't solve my problem.
My 4way blinker lights work. It's a switched ground system. I have power at the horn.
The circuit goes +12v at battery > hazard fuse > horn > steering column> when button pushed, ground
I have power at the horn, but no power at the spring loaded pin in the steering column (or the other side of the horn button, I'm not sure which way power is supposed to flow through that switch).
My broken connection must be between the horn and the steering column. The FSM labels this as a green-red stripe wire, but I haven't managed to trace it through the wire loom yet.
mussy01
Dec 13, 2016 08:20 PM
delmert
Sep 30, 2015 04:34 PM
Up&Down
Aug 11, 2015 10:04 AM
RBK
Aug 1, 2015 01:55 PM
gmonnie123
Jul 26, 2015 02:44 PM
