no fuel in filter???
Old Mar 18, 2009 | 04:41 AM
tyler88pu's Avatar
my brother broke a line off the strain on our 88 pick up. we whent to dealer and got anew one installed it and insstll new news from filter back. won't start replace fuel filter still nothing replaced pump still no gas in filter or anyone up. my question is do i have to prime the syteum?
Old Mar 18, 2009 | 05:20 AM
TNRabbit's Avatar
Is English your native language?? I find it difficult to figure out WTH you're asking...
What engine? What are your symptoms? You replaced the pump AND filter and have no fuel pressure? Is the pump running when you turn on the key?
Old Mar 18, 2009 | 05:51 AM
Tubbyfatty's Avatar
What?
Proper grammar helps...
Old Mar 18, 2009 | 06:17 AM
DupermanDave's Avatar
brother broke a fuel line. they went to the dealer and got a new one installed from the filter back (replaced the fuel line it sounds like)
truck wouldnt start, so they replaced the fuel filter. still won't start, so they repalced the fuel pump. They checked the fuel filter and there's no gas getting to/through the filter. no gas in the fuel lines it sounds like.
does this sound correct?
Old Mar 18, 2009 | 06:52 AM
tyler88pu's Avatar
yes
yes that's what happen. It's a carbed motor with a mechial(spelling sucks too sorry)fuel pump. i took the new fuel pump back because we didn't think it was the prob. my father and i think that the lines need to be primed is that true?
Old Mar 18, 2009 | 09:02 AM
874runnersr5's Avatar
it should prime when you have the key in the acc mode
Old Mar 18, 2009 | 09:25 AM
scuba's Avatar
you sure someone didnt get the fuel lines backwards..?
Old Mar 18, 2009 | 09:32 AM
b/s rules's Avatar
stock fuel pump?
Wile E. Toyote's Avatar
It's a Mechanical pump, won't prime with key on.
Have you cranked it a lot? Might take a bit to get the fuel up to the carb.
Old Mar 18, 2009 | 09:34 AM
tyler88pu's Avatar
we try to reverse the line didnt' help and yea i've even try starting fuild like 4 times trying to "help"
Old Mar 18, 2009 | 10:47 AM
ah, my bad
Old Mar 18, 2009 | 12:47 PM
space-junk's Avatar
this m,ay sound dumb, but is there gas in the tank??
Old Mar 18, 2009 | 12:53 PM
tyler88pu's Avatar
i ask the same question there's about a half a tank
Old Mar 19, 2009 | 01:26 AM
space-junk's Avatar
have you tried starting it while spraying carb and choke cleaner into the carb?
it always worked with my 81 firebird... maybe it just needs that extra boost to get going enough to create a vacuum...
Old Mar 19, 2009 | 06:22 AM
tyler88pu's Avatar
u tryed starting fuild and i'm goign to try it again but still nothing
Old Mar 19, 2009 | 08:25 AM
abecedarian's Avatar
aren't there 3 lines to the pump? one fuel supply, one fuel return, one vapor?
Old Mar 19, 2009 | 01:33 PM
tyler88pu's Avatar
it's a mechial pump so it's not at the tank it's up on the engine
Old Mar 21, 2009 | 07:59 AM
tyler88pu's Avatar
im going to have to drop the tank and follow all the lines i dont knwo what my brother did but it wasn't right lol.
Old Mar 22, 2009 | 09:37 AM
tyler88pu's Avatar
anyone have a diagram of teh fuel lines from the tank into the motor?
Old Mar 22, 2009 | 07:59 PM
Don't know if this helps:
The line on the left of the pump is the supply, the line on the pump- right / top, is the return to the tank, and the line on the pump- right / bottom goes to the carb.
*thanks yoterr
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
pyramid
Jul 30, 2015 10:05 AM
ddg71
Jul 24, 2015 01:24 PM
Fundy Rider
Jul 16, 2015 01:35 AM
