Newbie needs info on where to money for reliability
Hello. Thank you for looking at this post. I'm new here and I watched the video so I'd like to say that I went through dozens and dozens of postings before I came to the conclusion that I should post my own thread. So heres whats up.
I have an '86 4Runner. It has the 22re. Its basicly stock but it has a 3 inch body lift. I have about $1800 to put into it. This truck is my only vehicle. It is my daily driver. I love wheeling but I'm really more concerned with making this truck as reliable as possible. I'd also like to increase the power a little.
My buddie John says I should start with a header and exaust. Several posts in this site back that up. What I want to know, the reason for my post, is what engine parts, if any, should I replace or upgrade. I would like to make my money go as far as possible as i want to do some work to the interior as well. Any input will very greatly appriciated. Thank you!
Josh-
Josh-
welcome to yotatech... i would rebuild the motor useing www.engnbldr.com oarts then add a Lce header and a custom exhaust
x3 header and exhaust, intake can't hurt. Ignition upgrades, any and all parts could be upgraded. Steering setup is weak these years. I recommend an idler arm brace/gusset, at minimum. If you wheel hard, I say go with some high-quality, synth/semi-synth, gear oil in everything. If you wheel real hard, get the a-arm truss.
Wow! Thanks you guys! I can't believe I got help so fast! I am definately going to take your advice! Anyone else reading this, please keep it coming! Thanks again, I really appriciate it!
I don't wheel that hard, I don't think, but I don't want to break anything as I wont have money to repair it so I will be going with stronger grade parts.
THANKS Again!!
THANKS Again!!
if you dont plan on rebuilding the motor...then i would invest in a complete tune up, also do a compression and leakdown test..i would even go as far as having the timing checked along with the belt and water pump to see the age on them
just order a 1'' body lift from www.4crawler.com way less than 600 bucks
Thank you, I really want to rebuilt it, just since I don't know what kind of shape everything in there is in, it was allegedly rebuilt about 23,000 miles ago..but who knows what was done. I went to that website, engnbldr.com, and its rad but I've never rebuilt an engine before...and I only have the one truck to drive. Is there a place I can go localy (Sacramento) to have it rebuilt?
Wow. At www.4crawler.com ithat 1 inch lift is only $83.00! thats a great idea! Thank You!
Body lifts, interior, lift kits and exhaust are not going to make your rig anymore reliable. Invest in the basics first, tune up, coolant flush, thermostat, change all the filters and oil in everything. Flush and adjust the brakes, flush the clutch hydro system, grease all the stuff that needs greasing. How are your hoses, fuel lines, battery.
After that?s all done and up to snuff, your first investment should be an alarm since these early rigs get stolen a lot.
i took the motor out of my 93 pickup i use to have it was a 22re and it wasint that hard and i didint have a clue what i was doin if you take lots of pics and label all the hose and bolts you should be fine and theres plenty of people down there that i bet wouldint mind helping you
I just read this again and I want to clarify. Are you saying to have someone else rebuil the bottom and to rebuild the top myself? or am I just reading this wrong?
i meant you could have someone do the machine work to the bottom end install new pistons and crank and other parts needed then you could get a new head from engnbldr install that your self then do the timing chain too and sell your old motor almost complete and make a some money back
Why Rebuild?
All that and a dollar will get ya a double cheesburger
Jim
What are the benefits to doing this?
Not trying to be a smartass, but everything I've read indicates that a suspension lift won't give any more flex than a body lift, and in fact will make the truck less reliable on the trails and street because of the risk of bending or breaking a drop bracket...
Is this recommendation based on looks alone?
