New Truck, Trying To Figure Out Noise (Video Included)
Old Dec 4, 2019 | 01:46 PM
Awful_Economics's Avatar
I just bought a '88 22RE RWD Pickup with 136k miles on it. Engine runs well, completed a rather in depth tuneup on it and all is purring along nicely. However I'm experiencing a noise while driving that I think is probably the differential..
The Facts:
  • Sounds like a wurring, grinding noise.
  • Noise is only present when moving AND in gear.
  • Noise increases when throttle is applied but NOT when in neutral. Engine revs fine in neutral and no noise present.
  • Transmission shifts pretty smoothly and through all gears.
Steps Taken So Far:
  • Removed drive shaft from the differential and inspected pinon nut. Appears to be OK and tight.
  • Replaced Diff fluid. Very fine metal shavings attached to plug, but very very minimal in amount. Like, I had to pick it out with a tooth pick.
  • Backlash in the diff is present, maybe 1/4" in either direction?
  • Jacked up rear, put truck in neutral and spun rear wheels. Can for sure hear bearing noise but I'm not 100% sure it's what I'm hearing on the road.
I feel like it's probably in the diff. Should I even consider doing a rebuild myself or should I source a used one and just replace it?
I'm never done any differential work before so I'm not sure what constitutes normal and what's not.
VIDEO LINK: https://www.dropbox.com/s/8aeh1k8k53..._0375.MOV?dl=0
cpt_wonker
Sep 4, 2014 06:31 AM
LittleRedDevil
Dec 23, 2011 11:53 AM
dstn2bdoa
Jan 23, 2008 11:38 PM
4RocRunner92
Jan 13, 2007 04:00 PM
HaveBlue
10
Feb 15, 2003 10:41 PM
