new prerunner front bumper... QUESTIONS
Old Jan 26, 2008 | 07:02 PM
Morphine's Avatar
Well before you ditch the idea....work may be sending me out to Vegas for 5 days. If so i would be happy to stop by and lend a helping hand and see if we can't figure it out. Otherwise we can all just web-consult on how we think it should work. I'll find out tomorrow if they are sending me or not. Just an offer.
-=Morphine=-
Old Jan 26, 2008 | 08:00 PM
ozziesironmanoffroad's Avatar
sounds good dude, let me know. and i think its just bendy cuz of the rope. on the ground it looks perfect. remember it was being held with a rope hooked onto the latch for the hood.
Old Jan 26, 2008 | 08:02 PM
Originally Posted by AndYota
Here's how I did mine on my old '89. It has 2 L-shaped brackets for the upper mount. I think it was made by smittybuilt. Sorrry for the grainy pic, I had to scan an old photo.
The bracket connects #1 with one of the holes in #2 I think (pic below)
Andy
how are those supposed to bolt up? ones flat(frame) and the bumper bolt is not. do i need some kind of adapter or something?
Old Jan 27, 2008 | 09:48 AM
AndYota's Avatar
Yeah, that's where the extra "L" shaped piece is supposed to go. They came with the original bumper when it was sold new. unfortunately Smittybilt doesn't make that bumper anymore.
Old Jan 27, 2008 | 11:16 AM
  #25
any idea where to get the L adapter? or a pic of one so i can fab one up?
Old Jan 27, 2008 | 03:37 PM
  #26
SkiRig's Avatar
Yup, I got one of those. It is made by smittybuilt, you are missing the aluminum skid plate insert and the two L-bracket adapters. Maybe you can find a local shop to fab you up a couple of adapters?
I removed the stock skidplate and lower valence, but left the stock bumper on my first gen. I have it on my 2nd gen now, with the stock bumper modded to make it fit.
Old Jan 31, 2008 | 08:10 PM
  #27
ok this weekend im gonna give it another shot. gonna go to home depot and pick up 2 L adapters. my only question is: where the heck do i get the skid plate?
Old Feb 1, 2008 | 04:57 AM
  #28
Morphine's Avatar
Hey sorry for the delay but work is dragging there feet to see if they are sending me or not. Once I find out I'll let you know. Good luck this weekend getting her put on.
-=Morphine=-
Old Feb 1, 2008 | 04:58 AM
  #29
no prob man
Old Feb 1, 2008 | 08:38 PM
  #30
ok called up smittybilt, they said the bumpers are discontinued and any accessories are also discontinued. sorry for the inconvinence. lol. so my question now is: i can use home depot L brackets to mount it, but where am i gonna get a skid plate to fit it? i know i cant just use aluminum foil lmafao
Old Feb 1, 2008 | 09:17 PM
  #31
dropzone's Avatar
Fossilized
I would suggest that you hit up a metal place for some steel heavier than the Hope Depot stuff. The stuff they sell is such thin material that if you add a set of lights the vibration transmitted to the light bar will drive you nuts as the beam pattern bounces every where. You should be able to form something to work if you have got access to a vice and a BFH.
Metal place should also have some aluminum that you can form to match the curve. Just don't use diamond plate--it looks good but never understood why someone would use something designed to grip as a skid plate..
Old Feb 1, 2008 | 09:55 PM
  #32
Trustyrusty's Avatar
What you need to do is learn how to fabricate. Really dude, its NOT that hard to get that bumper to fit, you need some sheet metal, and some bolts.. and proper equpitment...
Old Feb 2, 2008 | 12:43 AM
  #33
Joe's Toy's Avatar
Dude! Nick we need to get together and hook that bumper up! You saw the way my lights are mounted? My friend welded me up a quick bracket for those things totally custom. Call me and we can get that thing put on easy. p.s. are you going to come watch the game? p.s. x2 where did you get such a good deal!? I've been looking but the cheapest I've found was like $300! Call me.
Old Feb 2, 2008 | 08:16 AM
  #34
and to think i was getting ready to go to home depot to get their heavy duty brackets. and joe PM sent
Old Feb 3, 2008 | 08:14 AM
  #35
N2Frodn's Avatar
I have the same bumper on my 86.
It is a smittybuilt (as others have posted), it goes on over the stock bumper and uses the bottom bolts for the factory skid plate and two L brackets that attach to the lower front bumper mounting bolts.
Since you are missing the factory brackets and need to have some fabbed up, there is a little trick that I used to make the bumper sit higher.
I had brackets fabbed up that attached to the upper and lower bumper mount holes so that the bumper mounting tabs lined up with the upper factory bumper mount holes. Had to slightly notch the bumper to make the brackets fit but the end result is MUCH nicer looking (and probably stronger) then having it riding low under the front bumper
EDITED TO ADD: I also had to bend the lower mount tabs (on the diff bracket) to match the change in angle. Overall, the bumper wound up about 2 1/2 inches higher in the front.
Old Feb 3, 2008 | 05:03 PM
  #36
ok, thanks to joe and tiger, its done. here are some pics. i have one that im not sure if i should post, since joes in it, but yeah. ill post all of em except that one.
Old Feb 3, 2008 | 07:09 PM
  #37
312necro213's Avatar
nice
Nice looks good, only complaint is no winch mount
Old Feb 4, 2008 | 04:27 AM
  #38
eh, im not really designin it to crawl over rocks, that will be the SA 4runner i buy sometime . thanks though
Old Feb 10, 2008 | 10:12 AM
  #39
bump for bringin back a dead thread. anyways, the bumper is mounted, and the lights are mounted as well. now my only complaint is no skid plate. do i modify the stock skid plate to make it bolt up to the bumper, do i look for a smittybilt skid plate someones got layin around, or should i fab one up? i cant offroad until i get one, im sad. .
Old Feb 10, 2008 | 12:19 PM
  #40
Morphine's Avatar
Any chance of a close up pic of the missing bracket and what you used to correct it? Thanks. Looks good by the way!
-=Morphine=-
