New headlights install
I bought a set of diamond eye projector style headlights off of Ebay that have the H4 bulbs in them. Is there a special way to install these headlights in a 92 Toyota. There were not instructions included and there are 2 orange wires and one black wire on the pigtails that came with the headlights. I know the black wire should be the ground wire. Do I need to customize my headlight wiring harness to make these work?
Thanks,
Doug
Thanks,
Doug
You can see the way the headlight bulbs are wired on my web page:
- http://www.4crawler.com/4x4/CheapTri...l#HarnessTypes
You can run them as-is, assuming the lamps are wired to match what Toyota uses, just plug in the 3-pin connector. You should test the voltage at the beack of the lamps and make sure it is adequate. Many Toyotas suffer from excessive voltage drops to the headlights.
Sep 4, 2015 09:27 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
