neutral safety bypass
As I was unable to find it anywhere, here it is: if you are needing to bypass the neutral safety switch, to either rule it out or temporarily bypass until its fixed, disconnect the plug that connects to the transmission at the nuetral switch location. The two wires needed to jump are the larger black and the black-yellow wires that feed into the female section of the plug. I used spade terminals to insert into the plug in order to easily put back to stock once repair is made. Otherwise, if you just want to jump it out and leave as such, I would suggest tapping into the "B" & "N" terminal wires that while still allowing them to feed into the plug. Essentially making an "H" with the wires.
Hope this helps someone looking to bypass a safety switch
83yotastockR
11
Nov 10, 2015 06:54 AM
kcaudill
Oct 10, 2015 02:39 PM
creecher10
Sep 30, 2015 03:27 PM
