need help no spark on 3.0
Old Feb 24, 2007 | 10:02 AM
saleen9973's Avatar
Hey guys i have a problem. The other day a valve started to tap real bad so i drove my 4 runner home and parked it. The next day went to start it and it wouldn't start it would turn over and try to almost start but nothing. I took the cap off the dist and checked to make sure it was turning and it is. I then put the cap back on and unhooked the coil wire and put a screwdriver up to it and cranked it and no spark, sorry a very very very tiny kind of spark. Two weeks ago i put a new cap and rotor on and it drove fine until that valve started to tap real bad. Can someone point me in the right direction on what i should check first. Thanks Pat.
Old Feb 24, 2007 | 11:31 AM
BadYOTA35s's Avatar
try swappin out ignition coil
Old Feb 24, 2007 | 12:11 PM
saleen9973's Avatar
I will give that a try, maybe i can find one on e-bay. Any other sugestions or any way i can check coil?
Old Feb 24, 2007 | 12:44 PM
saleen9973's Avatar
O.K. i checked the ohms at the coil and real quick they went to like .56 then real fast went down to .02 then 0 so i guess the coil is bad. Am i right?
Old Feb 24, 2007 | 01:21 PM
olharleyman's Avatar
Sounds like coil
Old Feb 25, 2007 | 06:49 AM
BadYOTA35s's Avatar
get one from auto zone...try it ....if it dont work..take it back...about 65 bucks.
Old Feb 25, 2007 | 08:13 AM
JEBSR5's Avatar
check all connections to coil and ignitor also. Leaving any codes?
Old Feb 25, 2007 | 11:20 AM
saleen9973's Avatar
Well i just started to do my HG job so the non starting thing will have to wait. Thanks for the help guys. I will post again when HG is done.
Charecter1
Nov 6, 2023 10:08 AM
wafoogalla
Nov 2, 2016 11:02 AM
old87yota
Oct 25, 2015 02:15 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
tobylab
Jul 12, 2015 12:53 PM
