need help 22re pops,backfires during acceleration
Old Aug 19, 2023 | 03:03 PM
jason317's Avatar
Good day masters,
i have a problem with my 22re , ive already replace the following, plugs, wires,rotor and cap, then replace injectors , replaced the afm , o2 sensors, new pump and filter, ive already changed head gasket new head works,,new seats and valves,valve seals ported im using an rv cam... heres the problem before i change al this things,, during hard acceleration the engine would backfires and bogs ,hesitates if you floored the pedal it keeps backfiirng and bogs down no acceleration.. no power..any help and suggestions would be much appreciated,,thanks in advance..
Old Aug 20, 2023 | 07:48 AM
Jimkola's Avatar
YT Community Team
5 Year Member
timing
Old Aug 20, 2023 | 08:08 AM
Discombobulated's Avatar
So have you replaced some of these parts to try to fix the issue or is this just stuff that was done cause it was due??
I concur with Jimkola on timing, if it’s way outta whack it will cause the symptoms you are describing, has the timing been checked??
Old Aug 20, 2023 | 08:51 AM
Robert m's Avatar
Spun balancer?
Old Aug 23, 2023 | 11:15 AM
87-4runner's Avatar
I concur with timing
Old Aug 23, 2023 | 02:44 PM
87yo_ta's Avatar
Timing chain caused mine to pop and sputter.
Old Aug 25, 2023 | 04:44 AM
jason317's Avatar
tested the timing .. marker is moving not stable moving back and forth even whe the cap is fix.. we also grounded e1 and te1.. at idle it misfires
Old Aug 25, 2023 | 02:07 PM
87-4runner's Avatar
THROTTLE POSITIONING SENSOR needs set correctly... if it's working. Unplug it and see how it run.
Old Aug 25, 2023 | 03:28 PM
Jimkola's Avatar
YT Community Team
5 Year Member
Just out of curiosity. Where does the bolt that locks down the distributor sit in the slot ? Kinda in the center, or way off to the side?
Yomanchu
Mar 2, 2016 10:28 PM
94playtoy v6
Jun 23, 2011 02:50 PM
Jonny207
Feb 16, 2010 10:52 AM
pntbol11
Sep 16, 2008 08:44 AM
