need AISIN manual hub faceplate or ideas!
Old Nov 12, 2011 | 05:29 AM
westjohns yota's Avatar
ok guys i cant get these hub bodies for the life of me, ive gone through about a can of pb blaster and alot of curse words, any ideas?
Old Nov 12, 2011 | 05:44 AM
waskillywabbit's Avatar
Brass drift and 3 lb sledge. Take your time and be patient. Once one is loose the rest will follow.
:wabbit2:
Old Nov 12, 2011 | 06:14 AM
well ive been working with a sledge for about 3 or 4 hours and they just wont budge, maybe im missing something?
Old Nov 12, 2011 | 06:27 AM
Use a brass drift to contact the hub bodies and the hub studs. Work around the studs hitting from the ends. Straight hammer blows will mushroom the ends and damage the hub body. Try hitting the hub body itself too from the top and the sides. The brass will absorb the damage and not mess up your hubs or studs.
:wabbit2:
Old Nov 12, 2011 | 06:38 AM
  #25
85TurboRunner's Avatar
I do the brass drift trick also but instead of a 3lb sledge I just use a small ball peen hammer.
I just use short quick blows and the washers shoot right off.
Old Nov 12, 2011 | 06:40 AM
  #26
will a torch help heating the hub body and maybe loosen the cone washers?
i want these hubs changed by 1
Old Nov 12, 2011 | 08:08 AM
  #27
wyoming9's Avatar
Wink
A torch could go either way it might help but i think not .
It would make it worse cooking out all the PB blaster.
Torch is good for nuts .
I have never even tried it although it is only a few steps away
Old Nov 12, 2011 | 08:25 AM
  #28
yeah craig im not sure, i have been tapping on these things since about 8 this morning and havent gotten a hub body off yet, theyeve been soaked with pb blaster and other pentrates and im out of ideas.... any one else care to chime in? no wheeling today
Old Nov 12, 2011 | 09:38 AM
  #29
Do you have an air chisel? One way I've done it is to just start the nut onto the stud so you cant mess the stud up. Then give it a zap with the air chisel.
Works every time. You mess the nut up but I have tons of them so I never cared.
Old Nov 12, 2011 | 10:17 AM
  #30
the stub holding the hub body on? i didnt think it would work and i have a few nuts left, maybe i can try that, missed my wheeling trip fml
Old Nov 12, 2011 | 10:19 PM
  #31
wyoming9's Avatar
Wink
I take it the air hammer is not a option??
Did you get these off yet ??
As I said the first time can be a real pain you need to break the cone washers free of the hub body as well as the studs .
The vibration from the air hammer works wonders!!
Myself I think being unable to get your hubs off in a reasonable amount of time far out weighs the bolts ever coming loose on my Warn Hubs at the wrong time
Old Nov 13, 2011 | 06:23 AM
  #32
air hammer is an option, just ran out of time yesturday until i had to work, ill get back on it today just getting a few things done around the house first!
PlayAwhile
Jul 20, 2015 11:36 AM
1996Taco
Jul 20, 2015 12:02 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
Poncho0206
Jul 10, 2015 06:21 PM
ItsJustD
Jul 7, 2015 07:49 AM
