name that part! (brake leak issue)
Old Aug 4, 2010 | 10:20 AM
JShaffer0525's Avatar
let me start of with the fact that im clearly a novice and i greatly appreciate any help i get!
anyhow, ive been having a leaking issue with my brakes. the fluid reservoir will drain after about 2 weeks. i believe the culprit is this part as ive followed the brake lines and see no evidence of a leak except around this part. part of the problem is i have no clue what this part is called even after reading everything about brakes in the haynes manual.
thanks in advance for the help!
Old Aug 4, 2010 | 10:31 AM
iamsuperbleeder's Avatar
LSPV
Load Sensing Proportioning Valve
http://www.ncttora.com/fsm/1990-1995...r/loadsens.pdf
Old Aug 4, 2010 | 10:33 AM
myyota's Avatar
That`s the load sensing proportioning valve. Try finding a good used one, as a new one can be a bit expensive.
Old Aug 4, 2010 | 10:35 AM
snobdds's Avatar
LPSV = Load Proportioning sensing Valve. It put's more braking power on the rear brakes when there is a heavy load in the truck. When you replace that part, which I would do, make sure you bleed that part LAST. Your brakes will never be right if you do it in some other order.
Old Aug 4, 2010 | 10:36 AM
snobdds's Avatar
Damm you guys type fast....
Old Aug 4, 2010 | 10:42 AM
thanks guys! much appreciated!
Aleeex_u
Jun 5, 2016 06:52 PM
voiddweller
19
May 2, 2016 09:10 PM
Lybrium
Jun 29, 2015 12:19 AM
WI Girl
Jun 25, 2015 03:45 AM
crazypaint
Jun 23, 2015 03:27 AM
