Mystery rear end play, feels like a U-joint but not
Old Jun 21, 2010 | 07:35 PM
dirtrider250's Avatar
Exclamation Mystery rear end play, feels like a U-joint but not
So driving my 93 3.0 4x4 it feels like a bad u joint. Let off the gas .clunk. get back on, clunk, again. So I checked the U-joints there all good. Sitting under the truck with it out of gear you can twist the drive line about two inches. So two inches of play. I thought worn spider gear? so I take out the third member. The pinion and ring gear look fine. Theres hardly any backlash. So now my question is where is that play coming from. Keep in mind that I know hardly anything about rear ends.
Old Jun 21, 2010 | 07:50 PM
devendwayne's Avatar
How about wheel bearing? Have you tried rocking the wheel side to side when its up off the ground?
Old Jun 21, 2010 | 07:59 PM
tc's Avatar
tc
How did you check the ujoint?
You need to really pry on it with some force - just wobbling it by hand isn't enough
Old Jun 21, 2010 | 08:01 PM
Not really but I'm sure I would of noticed it when I was taking the tires off. ???
Old Jun 21, 2010 | 08:05 PM
maybe, but there usually isnt a lot of slop in it. I would recommend checking them, doesnt take long at all, plus it will be something you can eliminate as a problem. Also, compare both sides to each other.
Old Jun 21, 2010 | 08:08 PM
retrospect's Avatar
I was having the same problem last week, minus the large amount of play in the driveline. But try replacing the carrier bearing or center support bearing. Mine was toast and i could lift the driveshaft and wiggle it about an inch in all directions. Now that its replaced i dont get the braking or acceleration "clunk."
Old Jun 21, 2010 | 08:23 PM
I don't think the u joint is the issue since there is that much play is the rear end?
Old Jun 21, 2010 | 09:41 PM
I just wanted to add the problem is definitely not it the u-joints. The shaft going into the 3rd member is solid. I check the driveline on my buddys truck in neutral you could barley move the driveline. Mine you can twist about a quarter turn. But to reiterate I took out the carrier and the gears are sound.
Old Jun 22, 2010 | 05:51 PM
Mcy17's Avatar
My 86 4x4 does the same thing. I'm hoping U joints will fix it.
Old Jun 22, 2010 | 11:57 PM
Matt16's Avatar
I think I'd be frightened to google "mystery rear end play"
crashburnoveride
Aug 28, 2015 09:20 PM
Yota.Jay
Jul 23, 2015 08:08 PM
andrewtexas123
Jul 14, 2015 04:29 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
toyoda8488
Jul 5, 2015 10:18 PM
