Old 03-30-2016, 03:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Steering & Suspension Guides
Print Wikipost
Mysterious power steering leak
Old 11-15-2013, 11:07 AM
Mr.Cheekers's Avatar
I had the same problem. Busted idle up p.s. Vacuum valve. My truck would puff smoke when I drove over rough stuff, the engine oil was overfull. I was losing fluid like crazy but no leak. I checked the idle up valve by adding leak detector dye. I use a black light to check the vacuum lines that run into the side of the intake, they glowed.
Old 11-15-2013, 12:25 PM
aviator's Avatar
I had that problem but on mine the ABS unit was leaking and it was all just "slipstreaming" away around the frame and axle [which is also under the PS pump] so tracking down the leak was a bear. It was also leaking brake fluid so we just disconnected the whole thing from everything.
tj884Rdlx
08-28-2015 12:04 PM
RaginAsian91
All Other Toyota Swaps
08-23-2015 10:27 AM
cars-guy
07-11-2015 07:51 PM
jon.r
07-11-2015 03:34 PM
nick b
07-11-2015 04:38 AM
Quick Reply: Mysterious power steering leak
