are my valves bent because my T.C. broke
Old Aug 25, 2007 | 02:26 PM
nickbean's Avatar
I am about to start a repair of a broken timing chain on a 91 4x4 with a 22re. my question is this: if I break my timing chain will it deffinately bend my valves? Or if it happened at low RPM and low load could the pistons have just simply nuddeged the valves gently out of the way? Or, could it have just stopped in a position that no contact could be made?
The reason I ask because when I applied around 90psi of compressed air through my conpression tester (sort of a make shift leakdown test) I heard no air throught either the intake manifold or exhaust pipe
please help I''d really like to fix the TC without taking off the cyl. head
thanks
Old Aug 25, 2007 | 03:40 PM
leebee's Avatar
methinks you have a job ahead of you, iirc, the 22re is an interferance engine. meaning...
good luck.
lee
Old Aug 25, 2007 | 03:48 PM
TORTIS's Avatar
i believe in God and luck. when your timing chain breaks neither are gonna help ya. when your timing chain breaks, and your piston slams into your valves, something is going to bend or break.
Old Aug 25, 2007 | 03:54 PM
highway's Avatar
.....x2
Old Aug 25, 2007 | 04:08 PM
slacker's Avatar
you'd be surprised how easily the valves bend ... god or not .. I say 2 are bent ..
DONT just bolt it back together , do a leak down test .
Old Aug 25, 2007 | 04:51 PM
SEAIRESCUE's Avatar
If you pull each cylinder to TDC and shoot 90 psi into the cylinder and you hear no leak at exhaust or intake, you are good..... this is the "acid test" and what a shop would do before going ahead with just a new chain install.
Count your lucky stars and get er done. Don't forget to check the valve clearances when done. The exhaust valves have a habit of receding into the head and cutting the clearances to zero as they wear from pressure and heat.
Old Aug 25, 2007 | 05:57 PM
linuxrunner's Avatar
i had a chain brake in a 22re with no damage. Good Luck
Old Aug 25, 2007 | 06:31 PM
stock87's Avatar
No damage isn't unheard of, but it is VERY rare. Definitely test first, unless you like doing a TC job twice.
Old Aug 26, 2007 | 07:10 PM
87TurboYota's Avatar
On my Turbo engine the chain broke and none of the valves were bent. However, I did go completely through the engine and rebuilt it right. So it does happen but not often since engines are interferance. Hopefully you are one of the lucky ones.
Old Aug 30, 2007 | 08:47 AM
nickbean's Avatar
thanx
well that's good news (I hope) I'm going ahead with the TC repair without taking off the head, as I heard no air past the valves.
thanx to SEAIRESCUE for the val adjust suggestion. Considering the timing chain was never replaced it's a good bet the valves need adjusting too.
I'm picking up the timing kit and gaskets today and I'll get it changed in the next few. I'll let you guys know how it turns out
Old Aug 30, 2007 | 09:42 AM
rdlsz24's Avatar
Why not pull the head just to be certain things are ok? It's easier to replace the timing chain cover with the head off anyway since you don't have to worry about munching the head gasket.
Rob
oldirtydirt
Feb 23, 2020 09:30 AM
jasonty
41
Dec 23, 2018 01:00 PM
Littlerick
Sep 10, 2015 08:57 PM
YOTATOY403
Aug 6, 2015 12:00 PM
yourrealdad
Jul 21, 2015 11:13 AM
