My timing chain replacement progress.
Old Jan 4, 2016 | 03:30 PM
piglett's Avatar
Originally Posted by d-wood
I meant to ask. Can I just dry fit my timing cover along with oil pump and pulley to check my lower dots along with upper or is that even necessary?
I would not even worry about the cover if it was me
I would just make sure the timing was dead nuts on before I went forward
i'm a bit odd so I would even go as far as starting the engine for 5 seconds to make sure it still runs. you want to have plenty of rags handy though
it will get messy with oil slinging everywhere.
Old Jan 4, 2016 | 03:45 PM
d-wood's Avatar
Right on piglett.
Old Jan 14, 2016 | 04:18 PM
d-wood's Avatar
I got the chain on along with tensioner and guides. Is the driver side suppose to have some slack in it?
Attached Thumbnails My timing chain replacement progress.-photo42.jpg   My timing chain replacement progress.-photo552.jpg
Old Jan 15, 2016 | 09:02 AM
piglett's Avatar
the slack will be taken up on the other side by the tensioner, rotate the engine over a couple times & if the marks are still right your "on the money". If not your a tooth off & you will have put the slop on the other side
Old Jan 15, 2016 | 09:32 AM
  #25
d-wood's Avatar
I did rotate it and my links lined up with the notches. So hopefully I'm good. I ordered some toyota fipg and the junk isn't here so I might just get some rtv for the head to timing cover. Where do I put that stuff? Do I apply it just under the head gasket or on top also.
Old Jan 15, 2016 | 05:32 PM
  #26
piglett's Avatar
I have not ever had a reason to do a 22r so i'm not sure of the exact process on putting the cover back on. I work on marine engines mostly. I would say search the web & find out what others have done with theirs
good luck
Piglett
d-wood
Jan 7, 2016 05:19 PM
Andy A
Dec 12, 2015 02:08 PM
John101477
Dec 10, 2015 11:35 PM
ward
Dec 10, 2015 10:35 AM
BrownRecluse
Dec 7, 2015 06:50 PM
