mounting a rollbar
Old Aug 15, 2008 | 06:36 PM
Cyberman's Avatar
I've seen the prerunner look, with the spare taking up most of the bed. Go Rhino makes a prerunner light bar with a bar running back the bed for a spare. I just don't see one for our trucks. And this bar mounts to the bed rails.
Old Aug 15, 2008 | 06:39 PM
toyNG's Avatar
trouble with that one ^^ is that it takes up the ENTIRE bed. kinda cool nonetheless
Old Aug 15, 2008 | 07:26 PM
T-1000's Avatar
Hey, kind of a thread hijack, but I've been thinking pretty hard lately on where to put a spare...
Shouldn't be under the truck, because that causes clearance losses.
In the back takes up the whole bed.
On the roof kills your gas mileage.
If you cut the back off a 4Runner though, would there be enough strength to support the spare on a swing out gate conversion?
EDIT: Actually, I think a good solution is mounting it on a swing out bumper.
Old Aug 15, 2008 | 07:37 PM
abecedarian's Avatar
why not get a set of the run-flat tires and not need a spare?
or maybe why not carry a tube or two so you can put some air into whatever tire goes flat?
Old Aug 15, 2008 | 07:44 PM
  #25
T-1000's Avatar
Or I could just get solid rubber tires...Not much clearance but it might work...Maybe if I got some portal gear axles...
http://www2.northerntool.com/product/200330352.htm
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
scott90
Oct 4, 2015 09:21 AM
voiddweller
Oct 2, 2015 07:47 AM
Brodetski
Sep 30, 2015 11:50 PM
