motor acting up
Old Oct 25, 2008 | 08:05 AM
abecedarian's Avatar
Originally Posted by baseballchamp157
I used the expensive gaskets from advanced discount auto. The cold start injector plug, does it have a plug on it? or is it the copper line with gas that hooks to the manifold?
the cold start injector has the gas line and an wiring plug, so disconnect the plug first, not the gas line.
Old Oct 25, 2008 | 02:18 PM
baseballchamp157's Avatar
ok and what should that do? so I know
Old Oct 25, 2008 | 04:06 PM
if the CS injector is spraying, disconnecting the plug should close it. if the plug is closed and the manifold heats up, you know it's something to do with the valve.
Old Oct 25, 2008 | 06:12 PM
what valve would that be? I dont know much about valves or wireing so please bare with me. but I will have to try tomorrow.
Old Oct 26, 2008 | 09:47 AM
  #25
well my motor is having a real hard time starting. well, actually it wont start so ill have to keep checking and trying but i might have to take it to a shop or somethin
Old Oct 26, 2008 | 10:49 AM
  #26
desert-rat660's Avatar
did someone put dry ice in your airbox haha
Old Oct 26, 2008 | 11:20 AM
  #27
TOYOTA 1's Avatar
if your motor is cold. you need the cold start injector to help get it started!
i think abe ment unplug it after it was warmed up!
Old Oct 26, 2008 | 11:41 AM
  #28
yea, i know what he ment. But even with it on its hard. idk its begining to become a pain. Ive put close to 6grand int his POS and Ima get rid of it when I get it running.
Old Oct 26, 2008 | 11:46 AM
  #29
TOYOTA 1's Avatar
6k.. wow.. yea at least it should run good and be reliable
Old Oct 26, 2008 | 11:55 AM
  #30
yea, that what i thought. I mean its been 1 thang after another since ive had it. so I think ive hit the end of my spending spree.
Old Oct 26, 2008 | 04:04 PM
  #31
why are u worried about the intake being cold? truck run ty?
Old Oct 26, 2008 | 05:11 PM
  #32
no the trucks running like crap. so somethings not right and im just starting with the obvious.
Old Oct 26, 2008 | 05:46 PM
  #33
instead of worrying why the intake is cold, let's get to the obvious.
Old Oct 26, 2008 | 08:38 PM
  #34
kinda what i was thinking
Old Oct 27, 2008 | 06:07 AM
  #35
well thats the most obvious to me. i mean obviouly omethins wrong if it gettin cold like that. so it might have somethin to do with my problem.idk. well before I replaced my intake gasket my truck cranked easy but sounded bad. After i replaced it it doesnt want to crank and it still sounds bad. but when i do finally get it cranked it runs and idles pretty good for about 20 seconds and then goes to crap.
Old Oct 29, 2008 | 10:09 AM
  #36
ok well i got it started and took of the cold start plug and all my truck did was die... anyone got another idea.
Old Oct 29, 2008 | 10:37 AM
  #37
1styota4X4's Avatar
what do you mean by freezing cold? Just cold to the touch or burn your hand like dry ice cold?
Old Oct 29, 2008 | 11:30 AM
  #38
like you cant hold your hand on it for more than a couple seconds cold
Old Oct 29, 2008 | 07:58 PM
  #39
johnnyboy's Avatar
cold start
Hey, of course the motor wont start if the cs inject. is unplugged!!!! start it then disconnect. It will close the injector and discontinue the fuel relase. You may have a leaking cold start, IS it hard to start the motor when the engine is warm? if so it is leaking.
Old Oct 30, 2008 | 04:05 AM
  #40
I did start it and then unplug. if you read right.
