Moist And My Pickup ,perform Better ,why??
Old 07-04-2007, 06:19 PM
Chief_Yota's Avatar
Question Moist And My Pickup ,perform Better ,why??
SINCE I HAD THAT TRUCK ,WHEN ITS RAINING OUTSIDE OR JUST MOIST,IT PERFORM BETTER,AND I CANT FIGURED OUT WHY??
heres what ive checked and changed:
-NEW; plugs,wires,sparkplugs,dist cap,alternator,batterie,injectors checked.
BRAND NEW and tuned TPS.,filter clean,
ive changed about everything since i just got out of a top end rebuild
no change at startup
no change in voltage(checked with a digital voltmeter)
SIGNIFICANT CHANGE IN MILAGE
SIGNIFICANT CHANGE IN POWER,RESPONSSE
now for what i think might be a problem ,correct me if im wrong:
-i NEVER changed the O2 sensor ,it as 240 000km on it,could moist affect the sensor??
-Grounds all around the batterie seems real skitish!
plz help.
Old 07-04-2007, 06:31 PM
ewong's Avatar
um.. damp air reduces pinging
Pinging detected by the knock sensor dials back the ign timing.
Its why turbo motors use water injection...
Old 07-04-2007, 06:35 PM
Chief_Yota's Avatar
wut the hell is that for an awser?
haha,so u want me to get a turbo to fix this? lol
Old 07-04-2007, 06:46 PM
91TPU's Avatar
i think what he is trying to say is maybe your timing is off, thus causing some sort of detonation, resulting in the knock sensor telling the ecu to go into a limp mode type of deal...
Old 07-04-2007, 06:53 PM
Chief_Yota's Avatar
ive double checked my timming with digital strobe light, its 15 advance dtc and i run 94 octane gas
Old 07-04-2007, 06:56 PM
91TPU's Avatar
why dont you go back to stock timing, unless that is stock timing...but if your running 94 octane i would say its prolly not...
Old 07-04-2007, 06:59 PM
Chief_Yota's Avatar
i was at 10 btdc ,but somebody told me to advance more if use of high octane fuel. do you think it might be the grounds on the batterie,maybe not making good contact so theres not enought juice for a good spark ?? or could the O2 sensor affect performance??,responsse?
i really dont think its the O2 sensor!!
Old 07-04-2007, 07:07 PM
Chief_Yota's Avatar
i meen thecnicaly what moist CAN DO:
-affect bad connections
-affect sensors ,only the ones that works with electronic pulse like 02 SENSOR!
-affect the detonation in the cylinder since moist affect spark.(but how in the hell whould it penetrate my oiled filter?)
-i dont see any other way moist can affect an engine!!
Old 07-04-2007, 07:10 PM
Chief_Yota's Avatar
And When The Engine Gets Hot ,it Gets Back To Like When Its Dry!!
Old 07-04-2007, 08:03 PM
CyMoN's Avatar
is the problem when it rains your truck runs like crap?
if so I have the same problem I am starting to think it is my maf
but I also know I need to replace the O2 sensor
my truck runs fine unless it is raining out or just rained this freaking sucks it stumbles if it is really wet out.
I even siliconed the dist cap to make sure no moisture could get in.
Old 07-04-2007, 08:09 PM
Chief_Yota's Avatar
haha i did silicone the cap too,but my truck runs great when its moist,im trying to tell poeple its running BETTER when wet!!im meen crazy better,so much difference that when its dry outside and i see a small water pit on side of the road i HIT it!! just so i think it might get better. lol but the big difference is when its raining outside or really moisty.
Old 07-04-2007, 08:13 PM
Jay351's Avatar
when its cold or wet = dense air, thus more power.
When your engine heats up it also heats the air it is intaking thus less power.. or so I see it..
Old 07-04-2007, 08:14 PM
91TPU's Avatar
did you put a new cap and rotor on? plug wires?
i noticed when i got my truck i was having the same problem, i replaced the rotor/cap and rtv the cap, and replaced my wires and the problem was gone, i think it was either worn contacts in the cap, or it was the plugs absorbing moisture...
what chief was saying tho is his truck is running better when its wet...
Old 07-04-2007, 08:16 PM
91TPU's Avatar
i still think its timing related, try and go back to stock timing, and run 87 octane like your supposed to...are you getting and knocking/pinging?
Old 07-05-2007, 12:53 AM
Zealot's Avatar
Well just a suggestion, if you think it might be your o2 sensor, and you have alot of miles on it, change it, they dont cost much.
Old 07-05-2007, 01:06 AM
stormin94's Avatar
Good point... but if you still insist it's something electrical, try some dialectric jelly. Put some on yer terminals, if thats where you think the problem is. I think it's the cool dense air thats doing it. Or maybe its the gasoline itself, Here in California, we have specially formulated gas for the summer that supposedly reduces smog, but makes yer car not have as much power and get bad gas mileage. In the wintertime, they change the formula, and you get better MPG, and more power. Its either the air or the gas, thats my call.
Old 07-05-2007, 01:33 AM
Drama Queen/Banned
paxil4x4's Avatar
Maybe your truck is a she, moist is always better when stabbing something
Old 07-05-2007, 02:37 AM
apalmer1's Avatar
the way i see it just by bassic process of elimination you can try using a spray bottle to squirt suspected trouble areas while its running and see what causes change. Though some things will obviously have a voltage increase just from being wet, like the alternator.
Also i saw this in an above post too but depending on what elevation your at the change in air density definately causes alterations in performance with N/A engines.
Old 07-05-2007, 05:17 AM
ewong's Avatar
Toyotas like OEM (NipponDenso) plugs.
Dont use Bosch Platinums etc...
Run stock timing.
Yes - the moisture will penetrate your oiled air filter.
Its mixed into the air in pretty small sized molecules, not as "rain drops".
The moisture will REDUCE detonation.
Thats why it runs better.
How much did they shave the head on the rebuild?
Old 07-05-2007, 07:00 PM
Chief_Yota's Avatar
no idea really ,not much thats for sure ,anyway im buying a new O2 sensor tomorow mornin,anyway it take 3 min to install and ill give you some news.
one thing is for SURE my timming is not affected by the knock sensor,ive replaced the wire and checked the sensor and it in perfect condition,and my timming NEVER MOVES a dime!!
Quick Reply: Moist And My Pickup ,perform Better ,why??
